Old 1st August 2009, 10:49 AM   #1
Default BJT's VCE.
Hey,
There's something which i dont quite understand about VCE in BJT's datasheet.
I take for example the P2N2222A datasheet.
1.
in the hFE category, for IC = 150mA & VCE = 10V* (2% pulse), hFE is guaranteed to be between 100 to 300.
If I apply continuous 10V voltage on VCE, would hFE remain between 100 to 300?
Do they apply a voltage pulse insead of continuous voltage to keep the BJT cool, and measuring hFE only when the
pulse is at its on state?
2.
In the VCEsat row, they claim that for IC=150mA & VCE = 10V*, VCEsat is 0.3V max.
I dont understand, if they apply 2% 10V pulse on the CE junction, shouldnt VCE be the exact applied pulse?
I dont understand how they reached 0.3V.
Thanks.
alphacat is offline
Old 1st August 2009, 05:40 PM   #2
1. hFE will be at the values stated for 10V Vce and the indicated collector current and temperature, yes.
They pulse test to limit the power dissipation so it doesn't heat up during the the test, and also to perform the test rapidly in production.
2. You caught an error in the data sheet. The Vce(sat) should be specified at a specific collector and base current. See http://www.eng.yale.edu/ee-labs/mors...ets/2N2222.pdf for example.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 1st August 2009, 05:58 PM   #3
Thank you C
alphacat is offline
Old 1st August 2009, 06:10 PM   #4
I looked at 25 datasheets but did not see the one with the errors about saturation voltages.
I asked before but nobody replied: Whose datasheet is wrong?
audioguru is offline
Old 2nd August 2009, 01:09 AM   #5
All of them (except Microsemi). This one is Fairchild PN2222A/MMBT2222A/PZT2222A Rev. 1.0.0 February 2009. Note that Vce cannot be 10V and 0.3V at the same time.
Collector-Emitter Sat Voltage * IC = 150mA, VCE = 10V    0.3
                              * IC = 500mA, VCE = 10V    1.0
de KI6RWX
mneary is offline
Old 2nd August 2009, 01:31 AM   #6
I looked at one dozen Fairchild datasheets for their PN2222A transistor and found a wrong saturation voltage spec in 2004.
They shouldn't let school kid NOOBs do their datasheets.
Old 2nd August 2009, 11:29 AM   #7
They've probably outsourced their datasheet department to India.
if I know the answer.
Hero999 is offline
bjt, vce
Output Charecteristic curve of BJT's Badar General Electronics Chat 2 26th April 2007 08:01 PM
recomend some BJT's and FET's clipo General Electronics Chat 12 29th August 2006 10:24 AM
