+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 34
Thread: Conductive Wire Glue ... a soldering substitue?
  1. #16
    Rotten organs Restal pus Newbie
    Join Date
    Jul 2009
    Posts
    11
    Quote Originally Posted by dknguyen View Post
    Why not solder? You still haven't answered this question.
    CAUSE I'M SCARED, OKAY?
    lol No, it's just that it's my first time soldering these pickup wires and I'm kind of hesitant. I thought it'd be a "cleaner" job if I went ahead with buying the conductive wire glue.
  2. #17
    dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,029
    If the wires are large it shouldn't be a problem. The difficult things about soldering is...well nothing really. It's just precision if the joint needs to be small.
  3. #18
    Join Date
    Jul 2009
    Posts
    11
    Quote Originally Posted by MrAl View Post
    Hello again,
    The resistivity is much higher than copper, as much as 500000 times higher,
    but for short distances it still comes out to low ohms.
    The test with the two wires was to twist them together about 5 turns,
    then dip the turns into the wire glue container and let dry. After drying,
    the joint measures zero ohms, but jumps up a little if you pull on the two
    wires a bit. It jumps up as high as 1 ohm sometimes, but then jumps back
    down. This does not happen with a straight non broken wire, which tells
    me that a joint made with wire glue subject to movement may change the
    resistance a little, so you would have to be aware of that. The resistance
    doesnt change much however, so with a guitar pickup it would most likely
    work if you twist the wires together first.
    I propose a test: do one set of pickups with wire glue (twist wires together
    first) and try it out with the amplifier of your choice. Remember that you also
    at least need some insulation over the wire glue too though, to prevent shorts
    to other joints in the same area.
    The pickup dc resistance is over 1k ohms, so adding 1 ohm in series with that
    isnt going to make a heck of a lot of difference so the wire glue should work
    for the guitar pickups. As i said before though, i would let dry for a few days
    and then coat with 5 minute epoxy for strength and added insulation.
    Hey thanks dude. But how do you manage to hold the wires? Will they stick right away?
    I asked someone on ebay, about this epoxy thing, who used the product and she said putting a bit of epoxy glue over the wire glue to strengthen didn't do anything good.
  4. #19
    Join Date
    Jul 2009
    Posts
    11
    No it's the pickup plate, right... It's a very tiny spot and lots wires are in there. So, I gotta be careful.
  5. #20
    MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,294
    Quote Originally Posted by Rotten organs Restal pus View Post
    Hello again,
    Well, when you twist the wire ends together that gives it the mechanical
    support it needs while the wire glue is drying. It's that simple. First
    strip maybe 3/4 inch from the ends of both wires to be joined, then
    twist them together maybe 5 turns or more. That puts them into
    good contact to begin with, even without the wire glue. Then, dip
    into the wire glue container and that coats then entire joint. You
    will then have to give it time to dry during which time the joint should
    not be moved at all.
    The next step, should you want to add more mechanical strength, is
    to add some 5 minute epoxy over the wire glue, plus a little more
    over the leads that still have insulation. This will add to the mechanical
    strength despite what that eBay'er said. Just make sure the epoxy
    also coats some of the leads where there is still insulation.
    The more epoxy the better here, and another idea is to tape the wires
    before the epoxy dries to something solid, like the guitar wood sides or
    bottom. Two small pieces of tape even better, one on each side of the
    joint (not over the joint). This will hold the joint with epoxy onto the
    wood which when dry will keep the joint from moving. This wont always
    be possible of course, when the wires are not long enough to allow this
    or they have to be able to move after the repair anyway.
    If you are really concerned about the strength, after the epoxy is
    applied before it dries wrap several turns of heavy duty 'coat' thread
    around the joint. The epoxy will soak into the thread and form a nice
    solid mechanical structure. You can even coat the joint a second time
    with the epoxy to get a stronger joint.
    Let me see if i can draw a picture of this...be right back...
  6. #21
    Join Date
    Jul 2009
    Posts
    11
    Hello again,
    Alright, very good.
    I shall try the glue. Now let me ask you this, what if I didn't make the connection after all, could it be cleaned off so I'd be able to try another application? What I mean of course is the pot and the volume knobs where wires will be glued on.
    And what kind of epoxy am I looking for? Does this one work?
    Amazon.com: Permatex 84101 PermaPoxy 5 Minute General Purpose Epoxy -- Crystal Clear: Automotive
    And how about a Solder Paste? Ever used that?
    Last edited by Rotten organs Restal pus; 22nd July 2009 at 06:40 AM. Reason: solderpaste
  7. #22
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    I understand your situation. A lot of us hesitate when we need to solder or first SOIC, QFP or whatever. We all wish there was a better/easier way to do it. After you have done it a few times it is not bad.
    Take the following as me telling you how I see it rather then as me telling you what to do.
    About time
    I have used the "Wire Glue". MrAl can confirm or debunk this but I found it to be unpleasant to work with. The viscosity is low and you have to use care. Like an ice cream cone in a new car. It seems to get on everything.
    I have a lot more experience with soldering then I have with wire glue but from my view point the glue will be a harder task than soldering.
    If you have enough room to twist the wires or dip them in glue you should have enough room to solder them.
    If you can raise the wires a bit and place a bit of aluminum foil under them to protect the rest of the circuitry/wires. Using a liquid flux pen to on the wires prior to soldering will help to. Use a 15 watt or temperature controlled soldering pencil.
    A closeup of the wires to be soldered would be interesting.
    If you do choose to glue use wax or parchment paper under the wire to protect the other wires.
    3v0
    BCHS/3v0's Tutorials
  8. #23
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,294
    Hi 3v0,
    My biggest complaint with the Wire Glue is that the container it comes in makes
    you think it is a jell or something, but it's not it's a liquid with a water base.
    The first time i opened it when it arrived in the mail i almost spilled the whole
    container out (he he) but lucky i caught it just as the lid opened...only a few
    drops spilled.
    I of course immediately started testing it after that. One of the tests was to
    run a longish dab on a piece of index card with wires running out both sides.
    This allowed me to test the resistivity and also how good it would be to make
    a custom resistor with. The resistance varies with temperature like a 10 or
    20 percent resistor so that's something else to keep in mind...cant be used to
    calibrate anything with a custom resistor value.
    Anyway, back to the OP:
    Yes that epoxy looks like it should work.
    I still agree however that soldering is the best.
    Solder paste has to be heated with an iron too.
  9. #24
    3v0
    3v0 is offline
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    MrAl,
    I had the same problem when I opened the container. But I lost more then a few drops. But it is not a problem in that what is left may be a life time supply.
    3v0
  10. #25
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,294
    Quote Originally Posted by 3v0 View Post
    MrAl,
    3v0
    He he, yeah that one little container will last me a million years :-)
    One other problem i forgot to mention, is that i find that the main
    ingredient in the formula seems to sink to the bottom of the container,
    so every month or so i have to re mix it. That gets to be annoying.
    I just checked it as i was writing, and sure enough, it's all jelled up
    and had to be mixed quite a bit this time. I missed last month's
    mixing! Geeze. Luckily it seems to be ok now.
    Shelf life may be limited. Maybe add a little water?
  11. #26
    Join Date
    Jul 2009
    Posts
    11
    Default Go with the solder
    You know what people, this thing sucked!
    I tried on one of my old guitars that needed some modification and everything, and it didn't do it.
    So I'm going with solder. Now, does it matter if I'm using an electrical solder or a metal work solder?
    And as for the gauge of the solder wire I'm using, which one's better in your judgment: .031" or .062"?
  12. #27
    be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    Don't use acid core solder. Use rosin core solder smaller is better for small wires.
    Burt
  13. #28
    3v0
    3v0 is offline
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    I had high hopes for it too.
    What be80be is correct. Acid core solder will corrode the joint in time. Personally I have never tried it.
    If you want to do a good job buy a liquid flux pen intended for electronic work. Wet the wires prior to soldering. But I think if you practice soldering on other wires first you will do fine either way.
    3v0
  14. #29
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    I did when I was kid my dad laugh at me and said looks good son. But wait till the acid insulates the wire from the lead by turning it green it did and stopped working never used
    acid core on wires agin LOL
    Burt
  15. #30
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,294
    Hi again,
    Oh so you tried some then?
    You know this stuff reminded me of, mud (ha ha) when i first saw it.
    I might try this on one of my guitars too, to attach a ground lead to the aluminum ground shield.
    I'll let everyone know what happens, how it works.
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. soldering 4 gauge wire
    By livehho in forum General Electronics Chat
    Latest: 27th April 2009, 08:57 PM
  2. Is hot glue conductive??
    By MrUmunhum in forum General Electronics Chat
    Latest: 5th April 2009, 09:01 PM
  3. Found "wire glue"
    By 3v0 in forum General Electronics Chat
    Latest: 6th December 2008, 04:27 PM
  4. Trouble soldering telephone wire
    By tab a in forum General Electronics Chat
    Latest: 24th January 2007, 01:06 PM
  5. Glue
    By shermaine in forum General Electronics Chat
    Latest: 10th July 2005, 03:28 AM
Tags for this Thread
