+ Reply to Thread
Results 1 to 11 of 11
Thread: how the diode will act in these situations in transition period
  1. #1
    Banned transgalactic Bad transgalactic Bad transgalactic Bad
    Join Date
    Apr 2008
    Posts
    240
    Default how the diode will act in these situations in transition period
  2. #2
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,945
    How accurate does it need to be?
    The simple approximation is to simply subtract the typical forward voltage drop from the power supply then perform the normal RC transient calculation.
    The more precise is to use the diode equation in conjunction with the RC transient differential equation. My maths isn't good enough to work it out so I'd turn to SPICE for help.
    if I know the answer.
  3. #3
    MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,283
    Hi again,
    Hero:
    Yes in many of these circuits they are using an ideal diode, with no
    voltage drop, but in these circuits they appear to be using a first
    approximation to a real diode which is an idea diode with a voltage
    drop.
    Transgalactic:
    In circuit 1 you have to figure out the initial capacitor voltage
    for when t<0, and that shouldnt be too hard.
    Then you have to find the time response up to the point where
    the diode conducts (sometime after t=0) and then the diode
    acts as a voltage 'clamp'. When the diode acts as a voltage
    clamp, it looks like an ideal diode (no voltage drop) in series
    with a small battery equal to the voltage drop v_0 with the (+)
    terminal connected to the cathode of the diode.
    In circuit 2, the diode is probably the same as in circuit 1, where
    it drops v_0 volts. The only difference here is that if it drops
    v_0 volts then it will affect the step response by subtracting
    v_0 voltage from the source.
    In the following drawing, Vb=v_0
  4. #4
    Join Date
    Apr 2008
    Posts
    240
    in the second circuit
    will the diode be open circuit
    or short circuit
    in the transition period
  5. #5
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,283
    It will be short circuit, unless you consider it to be like the diode in the
    first circuit when then it will drop a voltage equal to v_0 volts.
    For example, if v_0=0.7v then the diode will drop 0.7 volts.
    This means 0.7v will be subtracted from the unit step input.
    If you consider th diode to be totally ideal, then it will not drop any
    voltage.
  6. #6
    Join Date
    Apr 2008
    Posts
    240
    1.
    regarding the first circuit:
    "when then it will drop a voltage equal to v_0 volts.
    This means 0.7v will be subtracted from the unit step input."
    i know that when we have a positive voltage the diode will be short circuit
    so in time t>0 we have a positive voltage
    why its still an open circuit??(it should be short circuit)
    i cant understand this drop thing
    2.in both circuit there are cap's
    which in parallel to the diode so the voltage on the diode is the voltage on the cap
    and because vc(0-)=vc(0+)
    in 1st circuit vc(0-)=-v0
    in 2nd circuit vc(0-)=0
    so both diodes has to be open circuit in the transition period
    because there is no positive voltage on them
  7. #7
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,283
    [1]
    For the first circuit...
    For the time between t=0 and t=t1 the diode is an open circuit.
    It is open until Vc comes up to equal v_0. This means you
    have to solve for the time t1 when this happens.
    Since Vs=-Vo for t<0 that means you have to first solve
    for Vc(0-) and then take it from there to solve for t1.
    Keep in mind that in that drawing v_0 is not Vc(0), it is
    the diode drop (assumed to be constant).
    If you need to see the math let me know.
    [2]
    For 1st circuit, you have to solve for Vc and since Vs=-Vo
    then the voltage on the cap will be the voltage as if the
    diode wasnt there. When Vs goes positive, the cap starts
    charging positive and you then solve for t1.
    For the 2nd circuit, we assume Vc(0)=0, and for the unit step
    the peak voltage is 1-Vdiode, and so instead of the unit
    step we have (1-Vdiode)*u(t), which is less than u(t).
    For the impulse source however, the diode is insignificant even if
    it has a voltage drop, so the diode is a short for the impulse
    source. It will also be a short for the unit step response too
    but only if you consider the diode voltage drop to be zero (ideal diode).
    For the first approximation diode (vdiode=0.7) we would end
    up with a 0.7v voltage drop, for example, so the source would
    be u(t)-0.7 which is 0.3*u(t).
    For the impulse source, delta(t)-0.7=delta(t) which is no change.
    Note that in the 2nd circuit there is a postive voltage on
    the diode at t=0+ because the unit step or the impulse puts
    it there immediately and the cap voltage is zero.
  8. #8
    Join Date
    Apr 2008
    Posts
    240
    there is no u(t)
    in the circuit
    what is a drop?
  9. #9
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,283
    Sure there is... u(t) is the unit step function.
    A voltage drop is an increase or decrease in voltage between two nodes in
    the circuit.
    o----R----o
    n1        n2
    In the above, if n2 is at 5v and n1 is at 3v, there is
    a 2v voltage 'drop' between n1 and n2. If n1 is at 3v
    and n2 is at 5v, we still say there is a voltage drop
    between n2 and n1. Thus, when we say 'drop' the polarity
    is obvious from other references.
  10. #10
    Join Date
    Apr 2008
    Posts
    240
    ok so there needs to be a positive drop on the diode in order for it to work
    how the drop on the diode changes in both cases??
  11. #11
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,283
    Hi again,
    Yes the diode needs a positive drop (anode positive, cathode negative)
    in order to conduct current. There are a few differences with different
    diode models however. Here are three types:
    ['Vanode' is the voltage at the anode referenced to ground, and
    'Vcathode' is the voltage at the cathode referenced to ground]
    1. Ideal (perfect diode):
    This diode conducts perfectly when Vanode>=Vcathode.
    In other words, this diode is a short when Vanode>=Vcathode.
    and there is no voltage drop.
    This diode is a complete open circuit when Vanode<Vcathode.
    We might call this diode the 'perfect' diode, but it's often called 'ideal'.
    2. First approximation Ideal Diode (perfect diode with voltage drop):
    This diode conducts when Vanode>=(Vcathode+vd) where vd is the
    voltage drop of the diode when conducting, considered to be a constant
    over all time and for all currents.
    This diode does not conduct when Vanode<Vcathode.
    Once conducting, the diode acts as an opposing voltage source who's
    voltage equals vd, the characteristic voltage drop of the diode.
    3. Ideal Diode with Exponential Response:
    This diode uses the "Ideal diode equation" and that involves either an
    exponential or a log to calculate.
    This diode is like the first approximation diode, except that it has a voltage
    drop that depends on a log and a current that depends on an exponential:
    I=IS*(exp^(v/(N*Vt))-1)
    V=N*Vt*ln(i/IS+1)
    where N and IS are constants, and Vt is the 'thermal voltage' equal to k*T/q
    which equals about 26mv at 27 degrees C.
    This diode is used in more advanced studies though, and often includes a
    series resistance Rs.
    Now for these problems they are probably using either the perfect diode
    or the perfect diode with voltage drop.
    The two different diodes will make a difference when we go to analyze the
    response to a unit step because the one that has a voltage drop (like 0.5
    or 0.7) will act like a small battery in series opposing the source and so
    that subtracts from the unit step to produce a smaller driving voltage step.
    The diode that does not have a voltage drop (diode 1) will not subtract
    anything from the driving source, so the unit step remains the same as
    if no diode were present.
    On the other hand, when we go to analyze the response to an impulse it
    doesnt matter what diode we choose (1, 2, or 3 above) because the
    voltage drop does not matter. Thus, we can short out the diode when we
    analyze the response to an impulse, except that we also remove the short
    after t=0+. Thus, the diode conducts only around t=0, after which the cap
    charges up instantaneously and and when the impulse goes back to zero
    the diode goes to an open circuit.
+ Reply to Thread
  1. How to say which board was the first to detect a transition
    By atferrari in forum Micro Controllers
    Latest: 23rd August 2007, 11:35 PM
  2. Transition to widescreen monitor
    By SimonW in forum General Electronics Chat
    Latest: 31st July 2007, 01:37 PM
  3. Testing for transition 255 to 0
    Latest: 28th January 2007, 02:42 PM
  4. Pulse in negative and positive transition
    By leonel in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th January 2006, 08:00 AM
  5. state transition matrix
    By niga in forum General Electronics Chat
    Latest: 10th July 2005, 04:10 AM
Tags for this Thread
