+ Reply to Thread
Results 1 to 5 of 5
Thread: Laser for revolution counting...
  1. #1
    Wond3rboy Okay
    Join Date
    Jun 2008
    Location
    Hyderabad,Pakistan
    Posts
    470
    Blog Entries
    2
    Default Laser for revolution counting...
    Hi i want to know in what ways one can use a laser for counting the rotations of a wheel. Here are a few that i thought of(simple)
    1. Use a Reciver(LDR or something) on the other end and point the laser trough the rims.
    2. Use some sort of reflector(not very efficient since the 'reflector' can get dirty, inaddition to all the other problems).
    Any more??
    Syed
  2. #2
    dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    Depends on what kind of wheel you are trying to measure. Some don't even use a laser. They seem to just use ambient light (non-fluorescent) and count the "dark".
    Others don't need a reflector either. THey just read the diffuse reflection off of the wheel.
  3. #3
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,447
    If you can make some small grooves (0.1mm) into the wheel the laser will "see" the wheel rotating until it's surface has become perfectly smooth and even by dirt.
    Look at a CD. You can't see the pits in the aluminum, but the laser can clearly "see" them.
    Boncuk
  4. #4
    Wond3rboy Okay
    Join Date
    Jun 2008
    Location
    Hyderabad,Pakistan
    Posts
    470
    Blog Entries
    2
    Thanks for your replies.I want to measure the speed of a vehicle's wheel.So i thought that a laser would be a better approach. Tachometers are available to to calculate the RPM.
    About the diffused reflection by the tire, since it can get dirty it will become un predictable.
    Syed
  5. #5
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,447
    Look at the complete wheel arrangement of a car using ABS (anti-blocking-system) There is another wheel mounted on the axle of each wheel. It looks like a sprocket and is used in combination with Hall sensors.
    If the car has become dirty enough to make the sprocket even the system still recognizes the precise rpm of each individual wheel.
    May be it's a good idea to get away from laser detecting and use Hall sensors instead.
    Boncuk
+ Reply to Thread
  1. Replies: 3
    Latest: 25th February 2009, 12:13 PM
  2. TTL and Counting!
    By watzmann in forum General Electronics Chat
    Latest: 8th April 2008, 03:54 PM
  3. Replies: 2
    Latest: 27th May 2006, 11:31 AM
  4. Counting beyond f < 127?
    By Eric926 in forum Micro Controllers
    Latest: 8th April 2004, 01:30 AM
  5. digital revolution counter
    By amoremio in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th March 2004, 11:01 AM
Tags for this Thread
