+ Reply to Thread
Results 1 to 6 of 6
Thread: 12 vdc clock timer/switch
  1. #1
    frankvetrano Newbie
    Join Date
    Dec 2008
    Posts
    12
    Default 12 vdc clock timer/switch
    Hello everybody,
    I am searching for a switch (a clock switch).
    It should switch to "ON" from 6.00 am to 22.00 pm and to "OFF" in the remaining time.
    Does anybody tell me where can I find such a device?
    Is possible to do it by myself ?
    Thank you so much in advance.
    Cordially Francesco.
  2. #2
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    936
    Default 12 volts clock
    Francesco,
    Try to get hold of a quartz controlled analogue timeswitch with battery back up.
    This can be a 110 or 230 Volts one.
    Those clocks run usually at 1.2 Volts via the back up nicad battery when power fails.
    By taking out the voltage drop resistor or capacitor and refit a 1 k.ohm resistor in it's place here.
    Then refit the nicad space with a 100µF electrolytic capacitor and red LED in parrallel.
    The clock should work then. As added bonus the led will pulse at a 1 second rithm too.
    Please don't sent me private messages, I will not answer them.
    The questions asked can be discussed in the open forums.
    http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
  3. #3
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    936
    Default clock
    Like this one.
    I use one of those in my car succesfully for the last 20 years.
    The clock outlived a Ford Falcon for 14 years and is now in a Nissan diesel van.
    I use it for timekeeping only but you can switch things on or off if you wish.
    Regards
    Raymond
  4. #4
    im_in_asia_now Newbie
    Join Date
    May 2009
    Posts
    34
    What do you want to switch on and off?
  5. #5
    frankvetrano Newbie
    Join Date
    Dec 2008
    Posts
    12
    Dear Raymond, thank you so much for your email !! Yes I want to do something like you showed me in the picture. I have to switch ON/OFF a volumetric sensor of an allarm security device...just this. I would like to use a power supply of 12 volts, the same voltage of the sensor I have to switch ON/OFF.
    Thank you so much again,
    Francesco.
  6. #6
    frankvetrano Newbie
    Join Date
    Dec 2008
    Posts
    12
    Hi, thanks for you message. I need to switch ON/OFF an allarm security sensor. I want to deactivate the sensor from 6.00 am to 20.00 pm ...just this.
    Francesco.
+ Reply to Thread
  1. Using timer 2 for clock out on P1.0 of 89C450
    By kahlus in forum Micro Controllers
    Latest: 21st February 2009, 03:27 PM
  2. timer circuit for a clock mechanism
    By warlc in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st January 2009, 03:18 AM
  3. 1 Hertz Clock Timer
    By ormo in forum General Electronics Chat
    Latest: 27th November 2008, 03:39 AM
  4. clock/timer
    By j2k in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd March 2005, 03:11 AM
  5. Bidirectional Data/Clock Switch Question
    By Hopperito in forum Micro Controllers
    Latest: 25th January 2005, 01:05 AM
Tags for this Thread
