Old 10th July 2009, 05:31 PM   #1
Default Op amp power
hi all,
how could I determine how many op amps I can run off the same power supply?
I am trying to find out how many opa548's i can run from a power supply that says it can deliver 5A max. here is the data sheet for the op amp
http://focus.ti.com/lit/ds/symlink/opa548.pdf
sfink06 is offline
Old 10th July 2009, 05:38 PM   #2
Originally Posted by sfink06 View Post
hi all,
Probably a couple of hundred, but why would you want to? What is it that you are trying to do?
smanches is offline
Old 10th July 2009, 05:44 PM   #3
I am running some DC to HV-DC converters with these amplifiers, which take input voltage from a DAQ. someone mentioned that the power supply was limited to 5A, and that I should make sure that it would be able to run all 9 op-amps in the circuit at the same time. I don't know how many amps they need to draw from the power supply.
sfink06 is offline
Old 10th July 2009, 05:55 PM   #4
Well, now that I look a bit closer at the datasheet, I finally see the right figure.
Maximum continuous current output. +/- 3A.
So less than two running at full output current.
These are big ones.
smanches is offline
Old 10th July 2009, 06:06 PM   #5
These are big ones.
for my application the the converters draw about 1.5 amps, but I was hoping that on page 3 under power supply the listing of max Q current being +/- 20 mA would mean that I could run all nine. I wouldn't know how to even start dealing with the headache of switching between amps the whole time.
sfink06 is offline
Old 10th July 2009, 06:46 PM   #6
The Q current is the current that is being drawn when it is not in use, but still powered. It's the minimum current that it will draw at any time.
Looks like you may need a bigger power supply.
smanches is offline
amp, power
Swapping Batteries for a Computer Power Supply to power 16 circuits? yelm Electronic Projects Design/Ideas/Reviews 2 30th April 2009 10:20 PM
Power Designs bench power supply manual needed Cobalt60 Datasheet/Parts Requests 3 7th March 2009 05:19 AM
Will an Active PFC power suppy reduce your power bill? blueroomelectronics General Electronics Chat 10 4th March 2009 11:41 AM
solar power supply + backup power mabauti Renewable Energy 9 21st March 2008 06:22 PM
