ok, i am using an X10 remote power control box to trigger a circuit. so basically, when the wall power is turned on, it needs to start my 2 second timer. I am using one of those power supplies that takes AC and converts it to 12v DC. so basically, i want to have this 12v from the converted wall AC be on for 2 seconds. how do i do this? won't it destroy my circuit if i just run the 12v to the 555 trigger? i understand how to put a transistor on the output of the 555 with the collector connected to 12v, but how do i trigger it? thanks david
__________________ thanks, david | |
12 volts is ok. A simple trigger for a monastable looks like this: For your aplication, remove the switch and replace it with a transistor. The transistor is trigered by the same power that the control box Led is powered by. Thats if you have a Led in your remote control box ,and If I am understanding your question. | |
Screech's circuit will work, but requires that you push a button. If you want the power on to automaticlly start the timer, replace the push button switch with a .01 uF capacitor.
| | #4 | |
Hi! 12V is ok with a LM/NE555 and maybe some others. Read the datasheet before testing. Somes, like the TLC555, can't take more than 5V. | |
| 555, monostable, power, trigger |
