Hello.. is there a way tht we can make a pc oscilloscope which have atleast 20MHz of bandwidth??? ,, no matter what port to interface it with... can anybody provide me with circuit diag?
__________________ Rεσllγ !!! Mγ Σ×ρer!ence is Directly Propotional τΘ the NΦ of Electronic Items I have Me§§eD µρ . .. | |
If you're trying to DIY it to save money over buying one you're going to find them very complex and expensive to build from scratch.
but still i want to make it...
| Well make it then - there are various documents about then on the net, often university projects that people have designed for their final projects. You're probably going to need FPGA's to get the required speed, and fast memory to store to. | |
Bear in mind you'll need to sample at at least 40MHz but to be of any use you really need to go even higher. Sampling at 40MHz will cause you to loose most of the phase information at 20MHz. For example, you have two 20MHz signals 90° out of phase, they appear to be in phase because the deplay between the two signals is 1/80M 1/40M. I'd recommend sampling at 100MHz or even higher.
| | #6 |
Alternatively, you can use repetative sampling for periodic waves. You'll get better resolution, but you'll lose visibility for any transient behavior.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
| | #7 |
And, of course, you need a graphical interface that will display the measured data as a waveform on the PC screen. All-in-all building a PC digital oscilloscope from scratch is a very complex task. Unless you are an expert with high speed digital and analog circuits, your chances of success are not high.
__________________ Carl Curmudgeon Elektroniker | |
| oscilloscope |
| pic oscilloscope | fugrammer | General Electronics Chat | 4 | 21st November 2008 12:38 AM |
| Oscilloscope from a PIC | AtomSoft | Micro Controllers | 23 | 1st October 2008 11:00 AM |
| PC oscilloscope | wutang | Electronic Projects Design/Ideas/Reviews | 8 | 10th September 2006 01:04 PM |
| oscilloscope how to use it ? | Hetal | General Electronics Chat | 7 | 27th June 2006 05:59 PM |
| PC oscilloscope | metalbeard | General Electronics Chat | 1 | 4th June 2004 04:50 PM |
