Old 8th July 2009, 06:42 PM   #1
Default Question RE: NE555 pulse generator **added schematic**
I have a circuit using the NE555 wired in the typical astable operation. I am using ~6.1V input (Vdd). However my ouptput square wave is measuring 3.2V. I need the ouput square wave to be at least 5V.
What is causing this and what can I do to correct this problem?
FWIW I also tried using ~12V input but I kept burning up chips. It seems to work fine with the lower volate but I am getting the unwanted voltage drop.
Thanks in advance.
dwhitt is offline
Old 8th July 2009, 06:43 PM   #2
You probably have the output overloaded. Post a schematic of your whole circuit.
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 8th July 2009, 06:47 PM   #3
Thanks. I only have a hand drawn one at the moment but will try to come up with something to post before I leave today.
dwhitt is offline
Old 8th July 2009, 07:33 PM   #4
See if this works. I did this quickly and please keep in mind that drawing electrical schematics are not part of my job so forgive me if I got a symbol wrong.
The switch is actually a double pole double throw switch but the second switch is practically independent with its own power supply. The output of the relay is also on that second schematic.
I'm not sure what information you may need on the counter/timer. If you have specific questions let me know and I can look it up for you. Thanks again.
Question RE: NE555 pulse generator-schematic.jpg
dwhitt is offline
Old 8th July 2009, 08:49 PM   #5
The output of a NE555 (Fairchild Version) is rated at 100mA output at 5 volts, however at this output the voltage is down to 3.3 volts. Sounds like you have more than 100mA load on your output. The coil resistance of your relay need to be greater than ~100 ohms for a 5 volt relay.
bailey45 is offline
Old 8th July 2009, 09:01 PM   #6
Right. You most likely need a transistor to drive the relay.
ball.
BrownOut is offline
Old 8th July 2009, 09:15 PM   #7
Thanks for the inputs Brown and Bailey. Just to clarify... I need to put in a transistor between the output of the NE555 and the relay?
dwhitt is offline
Old 8th July 2009, 09:21 PM   #8
Yep, that is correct
axro is offline
Old 8th July 2009, 10:58 PM   #9
Something like this could get you started, assuming that the relay is small
Question RE: NE555 pulse generator-relaydrive.jpg
ball.
BrownOut is offline
Old 8th July 2009, 11:57 PM   #10
The TTL version is rated to 200mA, the CMOS version is rated to 100mA and that depends on the supply voltage.
What's connected to the output of the 555?
if I know the answer.
Hero999 is offline
Old 9th July 2009, 06:46 PM   #11
The relay is a Magnecraft W6225DSX-1. I don't see anything from the packaging that tells me the coil resistance? These are the specs they gave me:
  • Solid State Panel Mount Relay
  • Control Voltage Type: DC
  • Load Current RMS Max: 25A
  • Contacts: SPST-NO
  • Control Voltage Max: 32V
  • Control Voltage Min: 3V
  • Output Current: 25A
  • Output Device: SCR
  • Output Type: SCR
  • Output Voltage: 280VAC
  • RoHS Compliant: YES
The NE555 I have is (don't laugh) a radio shack brand chip (TLC555 Timer). High output current capacity Sink: 100 mA (typ) and Source: 10mA (Typ).
So this is what I purchased today- two NPN Silicon Transistor: one with an Ic of 3A and the other with 10A.
Please advise which transistor would be best and also please take a look at my updated schematic to see if this *Should* work. TIA.
dwhitt is offline
Old 9th July 2009, 07:05 PM   #12
I did't realize you were using a SS relay. Accordig to the data sheet, the input resistrance should be 1500 ohms, minimum. You're timer should be capable of driving that directly, unless I'm missing something.
Try disconnecting the relay and measuring the output of the timer. Maybe something else is going on.
ball.
BrownOut is offline
Old 9th July 2009, 07:13 PM   #13
OK. I will try disconnecting the relay, measuring the output.
Then connect doing the same with the timer. I will hold off on the transistor for now and report back.
dwhitt is offline
Old 9th July 2009, 07:14 PM   #14
Your circuit will not work as expected also the freq of the 555 is 75Hz, the relay will buzz.!
ericgibbs is offline
Old 9th July 2009, 07:15 PM   #15
Can you please elaborate on this? I am not sure I am understanding?
dwhitt is offline
ne555 pulse generator
pulse generator(like help) jesseyma07 Electronic Projects Design/Ideas/Reviews 3 20th December 2008 05:38 AM
1 kHz pulse generator using NE555 deva_raj24 Electronic Projects Design/Ideas/Reviews 1 17th November 2008 12:37 PM
pulse generator patroclus General Electronics Chat 5 20th February 2007 05:00 PM
pulse generator dark_conqueror Electronic Projects Design/Ideas/Reviews 6 28th November 2003 10:25 PM
5V Pulse Generator Brocktune General Electronics Chat 3 4th November 2003 09:11 PM
