Old 13th July 2009, 06:17 PM   #46
I guess I am still looking for ideas on how to correct this. It seems I am getting conflicting information regarding adding the transistor and diode circuitry. I have the transistor but don't want to solder it on until I am fairly sure that this will work.
When we suggested that, you had given us very little information about the devices you were using. After you showd us the SS relay, we agreed that the transistor and diode weren't needed.
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 13th July 2009, 06:30 PM   #47
Originally Posted by dwhitt View Post
Oh, and it is a TLC555 CMOS. Thanks again for taking the time to look at this!
Looking at the counter 4VA at 12V thats approx 330mA.
So the transistor will drive the counter.
Look at this simulation.
OK.?
EDIT:
R3 36R represents the counter.
Question RE: NE555 pulse generator-ssr7555a.gif
ericgibbs is offline
Old 13th July 2009, 06:55 PM   #48
Sorry, I hope I didn't offend. I really appreciate everyone's input with this. I just wanted to make sure it was a general consensus among all the experts before continuing. At the time when I wrote that comment, I didn't realize that everyone had agreed on that issue.
OK.?
EDIT:
Hmmm. interesting. This may take a while for me to digest. But it looks like it will almost be a redo for me. Just scrapping my design and starting over.
One question comes to mind though (and I know I am going backwards when I ask this) but it seems you interpreted 37msec pulse width to mean something different. The instructions I have says "The pulse test box should be calibrated for an output pulse width of 37msec." At first I interpreted it to mean as what you have (the total wavelegth to be 37msec). But then as I read the instructions of the complete test I think it means that it needs to be "on" for 37msec.
dwhitt is offline
Old 13th July 2009, 07:06 PM   #49
The basic 555 circuit is the same, its just the SSR drive and counter drive transistor... ignore the rightside of the circuit thats just a simulated SSR to keep me happy.
The transistor can be any 1amp npn device with a gain of about 50 at 330mA.
Ref the pulse width use the components that give you the pulse width that you need. I went for a total period of about 37mSec.
So its actually High for 37mS, low for 37mS thats required.
Have fun.!
If you need any more help, just ask.
Old 13th July 2009, 07:10 PM   #50
Thank you so much. I think I see what you are doing here. Basically the input to the counter will be the opposite of the Vout. That is ok because the counter I can change to count the "Ups" or the "downs".
Looks like I still need to change to a 12VDC power supply.
What is the diode and R6 for?
ETA: Also, is the D2 part of the simulated counter or does that need to be added as well?
dwhitt is offline
Old 13th July 2009, 07:20 PM   #51
Youre right about the ups/downs.
A 12Vdc regulated supply is required at least 500mA rating.
The Counter is most likely a solenoid, as Im not sure, [there maybe an internal transistor] the diode is there to protect the transistor.
Look at this image of the 37mS timing, I would split the 100K into two parts, say a 82K fixed resistor and a 50k variable resistor. This will enable adjustment of the timing.
R6 and the LED are the power ON indicator. Dont use a lamp.!
Question RE: NE555 pulse generator-aaaimage03.gif
Old 23rd July 2009, 09:14 PM   #52
As with most projects, the criteria has changed and I had to redo my board almost entirely. Instead of an astable operation, they now want a monostable operation. Here is the new definition of my problem:
They want a 37msec single pulse (generated by the 555 chip) to do two things: 1) send a signal to a counter to count the number of pulses, and 2) turn on a relay for the same 37 msec. After the pulse the relay should go back to zero. The pulses are commanded by pressing a button.
Here is the schematic that I came up with however it isn't working like I think it *should* work. From what i have read the trigger on the 555 IC is negatively triggered. That is why I had the NC button. However, when I press the button (breaking the contact to the trigger input) what I get is sporatic, nonreproducable results. Sometimes I get 10-20 pulses, and sometimes I get no pulses at all.
The other problem is that there is somehow some around 3V at the input of the relay when the trigger is still HIGH (meaning there should not be a pulse being sent)???
Any advise or words of wisdom?? Thanks in advance.
dwhitt is offline
Old 24th July 2009, 01:43 AM   #53
1) You didn't post your schematic
2) Who are "they"?
ball.
BrownOut is offline
Old 24th July 2009, 02:05 PM   #54
2) Who are "they"?
Oops sorry. Wrong file type. I corrected it.
"They" are the powers that be (aka my bosses)
dwhitt is offline
Old 24th July 2009, 02:36 PM   #55
hi DW,
I guess the relay is still SSR.?? and the electromechanical counter is the same.?
BTW: your circuit will not work.
Old 24th July 2009, 02:37 PM   #56
hi DW,
Yes. that would be correct.
dwhitt is offline
Old 24th July 2009, 03:17 PM   #57
hi DW,
Have a look at this 37mSec Mono.
Question RE: NE555 pulse generator-aaaimage02.gif
Old 24th July 2009, 03:18 PM   #58
Please do not label your TLC555 (it has low power Cmos) an NE555 (it has high power bipolar transistors). They are completely different.
Pin 2 must go low to trigger the timer. Your pin 2 never goes low.
audioguru is offline
Old 24th July 2009, 03:44 PM   #59
hi DW,
Thanks Eric. Is that a pnp transistor? I am using an npn ?
I don't quite understand what you are doing with the Myswitch? It looks like the trigger will go to ground when you push the trigger PB, but I am not understanding the symbology? Are you connecting the common of the button to the trigger, 12V to the NC side and ground to the Open terminal?
I have a friend who came across an old pulse test box and he gave me the transistor circuitry that is in my schematic. I was trying to match what he had even though he didn't know the exact circuitry outside the 555 chip. He was also able to provide the part number for the SSR. I'm guessing there is more than one right answer to this problem. I want to try the schematic you provided but I currently do not have the diodes. So I will have to go back to the store for those before I can test your schematic. I do appreciate all the time you have put into this.
Oops, sorry I did make the correction in my schematic in regards to the naming of the chip.
I guess I left this out in my previous posts, but I did connect the trigger to ground during my test and it still acted sporatic with unrepeatable results.
dwhitt is offline
Old 24th July 2009, 03:57 PM   #60
Is this better.?
npn transistor and the push button.
Remember the SSR in my dwg is for simulation.
Connect the OUT to the 'real' SSR +in terminal and the SSR -in to the 0V line.
Question RE: NE555 pulse generator-aaaimage02a.gif
ne555 pulse generator
pulse generator(like help) jesseyma07 Electronic Projects Design/Ideas/Reviews 3 20th December 2008 05:38 AM
1 kHz pulse generator using NE555 deva_raj24 Electronic Projects Design/Ideas/Reviews 1 17th November 2008 12:37 PM
pulse generator patroclus General Electronics Chat 5 20th February 2007 05:00 PM
pulse generator dark_conqueror Electronic Projects Design/Ideas/Reviews 6 28th November 2003 10:25 PM
5V Pulse Generator Brocktune General Electronics Chat 3 4th November 2003 09:11 PM
