I am using a 7805 5 volt regulator in a very simply ciruit that draws very little current. My problem is that the output of the regulator is not staying at 5 volts when the circuit is active. (Tests at a perfect 5vdc on the bench.) Instead, it drops anywhere from 4.9 to 4.75 depending on the load. It is not a transitory dip, it will stay at that voltage as long as the circuit is active. The supply voltage is a 12+ volt car battery. The circuit is a voltage divider -- essentially two 1K resistors in series from the output of the 7805 going to ground (with the voltage in between the resistors tapped for a low impedance data logger). One of the resistors is actually a thermistor, but it stays around 1000 ohms most of the time.
So, how do I keep the voltage at 5 without dropping like that?
