+ Reply to Thread
Results 1 to 10 of 10
Thread: induction to linear time invariant circuit
  1. #1
    Banned transgalactic Bad transgalactic Bad transgalactic Bad
    Join Date
    Apr 2008
    Posts
    240
    http://i44.tinypic.com/xfvv28.gif
    i know that i am supposed to use a convolution here.
    i tried to build Kcl on both nodes
    on the capacitor kcl:
    the voltage is Vc=L(I')
    -Is+CL(I'')+I2=0
    on the resistor kcl:
    -I2+(L(I'))/R+I=0
    (I is the current on the inductor which is given)
    this is as far as i could go
  2. #2
    BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent
    Join Date
    Jun 2009
    Location
    Huntsville, Alabama USA
    Posts
    1,942
    There's only one independent node. Only one KCL is needed. Try again.
    Lions and tigers and bears, OH MY!
  3. #3
    MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Hi BrownOut,
    Maybe you can walk him though this one.
  4. #4
    Join Date
    Jun 2009
    Location
    Posts
    1,942
    I can't see the attachment good enough to know what is being asked. I can see the ckt good enough to know it only has 1 independent node.
    Is-Ic-Ir-Il=0
    Besides, I'd probably make a mistake somewhere.
  5. #5
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Hi again,
    Oh, I didnt realize that some people couldnt read some drawings. I wonder
    why. In any case, here is a new drawing for anyone who cant read the original drawing. This might help a little.
  6. #6
    Join Date
    Apr 2008
    Posts
    240
    you can zoom on the link i posted
    just put the mouse on it
    and left click
    and it will enlarge by 3 times
  7. #7
    Join Date
    Jun 2009
    Location
    Posts
    1,942
    How much do you need this? I might be able to help, but you would have to wait till I can review 2nd order non-homogeneous equations. Refreshe me on a couple things, is the curly-delta the impulse function? If so, do you know the general solution to the impulse? Also, what is t'? The notation looks familiar, but remember I did this class almost 20 years ago.
    If you do a KVL, you get, after some manipulation:
    d^V/dT^2 + 1/RCdV/dT + 1/LCV = 1/C dIS/dT
    The slolutions to the homogeneous poly are
    S1 = -1/2RC + SQRT((1/RC)^2 - 4/LC); S2 = -1/2RC - SQRT((1/RC)^2 - 4/LC)
    (please check this for correctness)
    From here, you normally evaluate the discriminant to see if it's real, imaginary or zero.
    Can you take it from here? Or do I have to do some more review?
  8. #8
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Quote Originally Posted by BrownOut View Post
    Hi again,
    I would do this in latex too but gee it takes so long to form the equations
    even using the editor. It sure does make a nice looking set of equations
    though.
    Following BrownOut's kick start...
    The circuit contains two nodes, and with nodal analysis we need to look at
    N-1 voltages and N-1 equations, but unfortunately, we dont need to analyze
    the voltage so forming an equation that contains voltages wont be as easy.
    Instead, since we need to look at the current in the inductor anyway we start
    looking at the currents with KCL:
    vC/R+C*d(vC)/dt+iL=Is (vC is cap voltage, iL is inductor current)
    which is of course the sum of currents equated to the source.
    This equation still depends on voltage however, and we wish to eliminate that
    so that we can end up with an equation that depends entirely on current, so
    taking into account the following relationship between current and voltage in
    the inductor:
    v=L*di/dt
    where i is the current in the inductor and v is the voltage across the cap, so
    vC=L*d(iL)/dt
    Substituting this into the first equation above we get:
    (L*d(iL)/dt)/R+C*d(L*d(iL)/dt)/dt+iL=Is
    Doing the math we get:
    L/R*d(iL)/dt+C*L*d^2(iL)/dt^2+iL=Is
    and rearranging a little and replacing iL with i we get:
    C*L*d^2i/dt^2+L/R*di/dt+i=Is
    which is a second order differential equation that depends only on the inductor
    current i=iL.
    [Note: a little more accurate representation of this equation would be:
    C*L*d^2 i(t)/dt^2+L/R*d i(t)/dt+i(t)=Is
    but we are using 'i' as shorthand]
    Now since the first step is to make Is equal to an impulse, the response will
    be the impulse response and from the interpretation of the impulse response
    for a network we get:
    C*L*d^2i/dt^2+L/R*di/dt+i=0
    That is, the response to an impulse (curly delta) is simply the unforced response
    of the network.
    The next step would be to solve the differential equation and find the initial
    conditions corresponding to t=0+ .
    BrownOut:
    I had to refresh a little too as i had learned other techniques that are much
    quicker than the approach that problem apparently wanted us to use.
    I also used Laplace to find the initial conditions, perhaps you can remember
    another simpler way to find these and refresh us both :-)
  9. #9
    Join Date
    Jun 2009
    Location
    Posts
    1,942
    I would have used Laplace too, but generally when a student is solving equations using this method, they don't have Laplace yet. That's why I had to review this method.
    Or maybe I made an assumption about what you had to use. Is this a class assignment? For some reason, I made that assumption.
  10. #10
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Yeah, i was thinking that too that's why i was thinking about another
    way to find the initial conditions at t=0+ . In particular, di/dt (0+)
    where 'i' is again the inductor current.
+ Reply to Thread
  1. need correction about linear regulator circuit
    By zhi_yi in forum General Electronics Chat
    Latest: 30th October 2005, 04:48 AM
  2. Way to charge a capacitor linear over time
    By e-l-e-c-t-r-o in forum General Electronics Chat
    Latest: 30th September 2005, 02:33 PM
  3. project for linear integrated circuit analysis
    By milobond in forum General Electronics Chat
    Latest: 5th September 2004, 04:00 AM
  4. Firing Circuit for Induction Heating
    By Riyazahmad in forum Electronic Projects Design/Ideas/Reviews
    Latest: 31st August 2004, 01:31 AM
  5. 0-10A and 0-30V Linear Power Supply Circuit
    By Candy Yiu in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd July 2004, 01:56 AM
Tags for this Thread
