Old 5th July 2009, 05:24 PM   #1
Default Resistors and LEDs....
Knowing what resistor to use is way to confusing for me. I thought I had figured it out. But then I started taking junk apart and trying to figure things out. I have run into a confusing issue. Almost every white 5mm LED I have used/seen requires 3.6ish V to 4.0 V max, but I have seen them with 5V going to it with just a resistor on it. Why isn't that LED burning out? Or is it the max current that matters?
limlik is offline
Old 5th July 2009, 05:45 PM   #2
The value of the resistor is chosen so that it limits the current thru the led to the specified value.
Typically 10mA to 20mA for standard leds.
ericgibbs is offline
Old 5th July 2009, 06:04 PM   #3
Ok, but why does it say a max voltage and yet I see LEDs being used with a higher voltage?
limlik is offline
Old 5th July 2009, 06:09 PM   #4
The resistor drops the higher voltage down to the lower voltage for the led.
Example: say the white led is rated at 4V at 20mA and you have a 5V supply, you need to drop 1 volt across the resistor.
Ohms Law says R= V/I ,, Res= 1V / 0.02 = 50 ohms
So, subtract the led voltage from the supply voltage and divide the answer by the led current.. answer in ohms
OK.?
Old 5th July 2009, 06:54 PM   #5
So hooking a 2.6v max red LED 60 mA to a 4.5v power supply I would need a?
limlik is offline
Old 5th July 2009, 06:58 PM   #6
A standard RED led would only handle about 20mA
So 4.5V - 2.6V = 1.9V so Resistor is 1.9v/0.02 = 95R say 100ohm
Old 5th July 2009, 07:06 PM   #7
Isn't a standard red LED, misread is 50 mA, it is a full color LED.
limlik is offline
Old 5th July 2009, 07:08 PM   #8
Current limiting Resistor calculator for leds is a useful site
Jim
jimmythefool is offline
Old 5th July 2009, 07:14 PM   #9
All you have to do is:
So 4.5V - 2.6V = 1.9V so Resistor is 1.9v/0.05 = 38R say 39R
Old 5th July 2009, 07:16 PM   #10
Ok, so before I go trying something dumb with these I want to double check that I am reading the info correctly. When the box says FW supply this means?
limlik is offline
Old 5th July 2009, 07:18 PM   #11
Do you mW milliWatts?
Old 5th July 2009, 07:35 PM   #12
it says "FW Supply: 2.0V Typical, 2.6V max (Red)
limlik is offline
Old 6th July 2009, 12:54 AM   #13
FW supply means the voltage drop across the LED measured from the posistive to the negative.
A LED act like a zener so for 2.0 Volts the LED will be bright.
When at 2.6 Volts the LED will be at it's maximum voltage and perhaps a little brighter.
It is always good practise to underrun the stated LED max. currents and max. voltages.
20 mA LED run at 15 mA
2.4 Volts across LED in above example.
Please don't sent me private messages, I will not answer them.
The questions asked can be discussed in the open forums.
http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
RODALCO is offline
Old 6th July 2009, 02:37 AM   #14
Hi limlik,
may be you can use this little schematic for better understanding.
If the calculated resistor value is not a standard value, e.g. 170Ω, use the next higher standard value (180Ω) - never a lower one!
Boncuk
Boncuk is offline
Old 6th July 2009, 06:47 PM   #15
Always use the nominal voltage drop, not the maximum voltage drop and use the recommended operating current not the absolute maximum.
Round the resistor up to the next preferred value not down, especially if you're using a current close to the maximum. For example, if you calculate 50R, use 56R rather than 47R.
if I know the answer.
Hero999 is offline
leds, resistors
Resistors and? Electronman General Electronics Chat 132 11th May 2009 03:43 AM
Resistors and parallel LEDs Atmaweapon General Electronics Chat 2 11th March 2009 01:41 AM
LEDs, internal resistors, large Vf 3v0 General Electronics Chat 30 20th July 2008 05:04 AM
Question about LEDs and resistors. tribaloverkill Electronic Projects Design/Ideas/Reviews 5 1st November 2004 05:55 AM
LEDs-Super Bright White LEDs $1.35USD ea ssullivan777 Datasheet/Parts Requests 0 27th February 2003 03:02 AM
