+ Reply to Thread
Results 1 to 6 of 6
Thread: diode question..
  1. #1
    Banned transgalactic Bad transgalactic Bad transgalactic Bad
    Join Date
    Apr 2008
    Posts
    240
    diode question..
    the question is here
    http://i40.tinypic.com/2m2flax.gif
    when the diode is letting currect flow threw it
    we have
    V=4e^(-0.5t)+2t+4
    when the diode is not letting currect flow threw it
    we have
    V=2t
    what next
  2. #2
    MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Quote Originally Posted by transgalactic View Post
    we have
    V=4e^(-0.5t)+2t+4
    we have
    V=2t
    what next
    Hello again,
    Since part of the text is missing (that pic cuts off the last part of the text)
    i have to guess that they are asking us two questions here:
    1. To find the voltage response across the capacitor to a ramp current 'is'
    2. To compare the derivative of the result to the current through the capacitor
    and decide if the current through the capacitor is really the derivative of the
    voltage across it.
    In other words, the text would read:
    For the circuit shown in Fig P4.24, calculate the ramp response across the capacitor,
    that is, the response v due to an input is(t)=r(t) with v(0)=0. Is the cap current
    response for the circuit the derivative of the (voltage) ramp response?
    If so, then the way to go about it is to first calculate the voltage response as
    you already have done (but check your accuracy) and then take the derivative
    of that response, call that dv/dt. Then, calculate the current response through
    the cap and compare this to the previously calculated dv/dt to see if they are
    indeed the same, or different.
    The true voltage response is:
    v=IS*(4*e^(-0.5*t)+2*t-4)
    for 'is' being a ramp r(t)=IS*t.
    so you should check your accuracy first, then proceed with the rest.
    BTW you should be able to guess the result before you even do any
    additional work, but i believe you should verify that too.
    Let me know what you come up with ok...
    In the future, try to get better pics so parts of the text are not missing.
  3. #3
    Join Date
    Apr 2008
    Posts
    240
    the full text of the question is:
    "for the circuit shown in fig p4.24 calculate the ramp response v(.) ,that is the response "v" due to an input is=r(t) with v(0)=0.is the step response for the circuit the derivative of ramp response."
    in the end of the equation i got -4 that the only mistake i see.
    i cant see were is my mistakes in the getting the ramp response:
    Is=Vr/2 +1*Vr
    for t>0
    t=Vr/2 +1*Vr
    (currect equals time because its a ramp graph)
    then after making superposition of zero state response with the zero input response ,i get
    Vr=C*e^(-0.5t)+2t-4
    in I(t)=0 so C=4
    and we get
    Vr=4*e^(-0.5t)+2t-4
    so we need to say is the "is the step response for the circuit the derivative of ramp response"
    and
    i dont know what equation to take
    there is a diode which gives us a different equation for each of state of it.
    and i am not sure if my way of thinking is correct
  4. #4
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Hello again,
    Ok, so they are asking if the step response equals the derivative of the
    ramp response.
    So what you need to do is to find the ramp response (you already did this)
    and then find the step response, then take the derivative of the ramp response
    and compare that to the step response. If they are the same then the answer
    is "yes", but if not, then "no".
    I think you should be able to find the step response if you already know how
    to find the ramp response, right?
    About the diode...
    There are two ways of looking at what an "IDEAL" diode really is:
    1. An ideal diode using the ideal diode equation that relates current to voltage exponentially.
    2. An ideal diode that takes:
    Id=0 when Vd<=0 and
    Id=I when Vd>0
    which simply means the diode is a short when current is flowing in the positive
    direction and open otherwise.
    You would need to know some background information in order to judge the
    context of what type of ideal diode they are talking about, but i would bet it
    is #2 above unless this is a more advanced course or something. Also, they
    didnt give us any diode parameters like N and IS so we couldnt use the
    exponential model anyway.
    In that case, as long as there is current flowing from the current source to the
    capacitor then that diode is a short circuit...zero ohms. Thus, the equation
    you got when the diode is conducting is the correct equation to use for the
    comparison.
    Proceed like that and see what you can come up with for the step and derivative
    of the ramp response.
  5. #5
    Join Date
    Apr 2008
    Posts
    240
    yes i got
    Vr=-2e^(-t/2) +2
    for Cs diod
    and Vr=2 for Open circuit diode
    so the idea is to take the equations of each diode situation
    and compare each pare
  6. #6
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Hello again,
    Well, the idea is to compare the derivative of Vc with the ramp input and
    compare that to the step response of Vc. The diode ends up conducting
    all the time for both.
    We both got:
    Vc(with_ramp_input)=IS*(4*e^(-t/2)+2*t-4)
    and the derivative of that is:
    dVc/dt=IS*2*(1-e^(-t/2))
    and the step response is:
    Vc(with_step_input)=IS*2*(1-e^(-t/2))
    and since
    dVc/dt=Vc(with_step_input)
    the answer is "Yes".
+ Reply to Thread
  1. Zener diode question
    By potoole64 in forum General Electronics Chat
    Latest: 26th October 2008, 06:19 PM
  2. 12 volt diode question
    By hot rod otis in forum Chit-Chat
    Latest: 25th May 2008, 09:26 PM
  3. Quick Diode Question
    By TrevorP in forum General Electronics Chat
    Latest: 29th July 2007, 02:21 PM
  4. Diode Question.
    By bitem2k in forum General Electronics Chat
    Latest: 3rd March 2007, 10:20 AM
  5. Diode Question
    By troy310589 in forum General Electronics Chat
    Latest: 28th June 2006, 02:08 PM
Tags for this Thread
