+ Reply to Thread
Results 1 to 3 of 3
Thread: help me with this circuit
  1. #1
    ashparalikar Newbie
    Join Date
    Jul 2009
    Posts
    1
    Default help me with this circuit
    the shown diagram i have used as current to voltage converter in the case of photodiode. pin 1 corresponds to cathode of photodiode and pin 2 corresponds to anode which is grounded.
    i am using INA128... please help me about the working how the current is converted to voltage in this case...
  2. #2
    MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,866
    The INA128 is a differential input instrumentation amplifier. It is designed to amplify a small voltage difference applied to pins 2 and 3. It is not designed to act as a "current amplifier" for a current injected into one of the inputs.
    The photo diode should be connected cathode to +12V, anode to a resistor the other end of which is grounded. Connect pin 2 of the INA to the anode of the photodiode.
    This way, the reverse leakage of the photodiode is modulated by incident light, and this current creates a small voltage across the resistor. This small voltage is amplified by the INA.
  3. #3
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,871
    The second way to use a photo-diode is when it has no bias voltage. Then it generates a tiny current the same as a solar cell. Since it has no bias voltage then it has no "dark current" and it capacitance is higher therefore its response is slower than the reversed-biased way.
+ Reply to Thread
  1. electronic earth leakage circuit breaker circuit diagram
    By jideadido in forum General Electronics Chat
    Latest: 21st September 2009, 03:21 PM
  2. Need a Dual Power supply circuit diagram for an LM107 Circuit
    By Qaiphyx in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th July 2009, 07:21 AM
  3. Timed Robot/Circuit - NEED A CIRCUIT TO TURN LED ON AND OFF AT SPECIFIC INTERVALS
    By zaidpirwani in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th June 2009, 10:54 AM
  4. Creating a remote circuit using a cell phone and circuit board kit.
    By gluon_spin in forum Electronic Projects Design/Ideas/Reviews
    Latest: 6th November 2007, 05:44 PM
  5. 40% duty cycle square wave generator circuit.I need help to develop this circuit
    By navinthan in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd November 2006, 08:57 PM
Tags for this Thread
