Hi all, I'm new to this forum. I posted in Electronics Projects forum but had no response, so, trying here. I've just started dipping my toes into the electron stream and it's not as easy as I thought it was. I'm a technical guy (web designer) but I've gotten lost on my project. Can you help? I've got a small mono amp operating on 9 volts. It has a sound input which is powered by the amp – about 1.2v. It then outputs to a 1 watt 8 ohm speaker. This all works perfectly. Now, what I want to do is connect the output of the amp to a voice recorder circuit. The voice recorder is designed to play a sound only (we use the VR because we can record funny sounds on it). It has a momentary switch which plays the digitised sound. I hooked up the amp output to the momentary switch input and got the voice recorder to make the digitised sound based on the amount of voltage being generated by the amp. The DC voltage is 0.00 and the AC runs between 0.00 and 600mV depending on it the output from the amp. Here's what we want to do: When the sound plays (active AC voltage) we don't want the voice recorder circuit to play any sounds. When the amp stops outputting sound (no AC voltage) or the voltage drops below a certain threshold, we want it to trigger the voice recorder and play it's digitised sound (probably a fart sound or something). The VR sample will run for about 1 to 2 seconds. I know this should be simple but I just can't get my head around it. Not sure if the voltage needs converting to DC and then storing in a capacitor to release when the voltage drops (no sound from amp). That way could it make a momentary circuit? So, to recap. There are two circuits: 1 watt mono amp – operates between 4.5v and 9v. 20 second voice recorder which has a built in mic and speaker – operates between 4.5v and 6v. Then there is the external speaker for the amp and an input – either a mic or an mp3 player. My electronics knowledge is basic so any help would be most welcome. Treat me gently though because my knowledge does not extend very far. This is a project for my kids – I promised I would do it! Here's hoping, Rees. | |
What happens if you keep the play button on the voice recorder, pressed.
Hi Colin, If you keep the button pressed then it plays and then stops. If you press play intermittently then playback is interrupted and short bursts of sound are emitted. Cheers, Rees. | |
Place an NPN transistor across the switch and connect the base to a 10k resistor. Feed the base resistor with say 3v and let me know if this will activate the module (voltage between base and emitter). | |
Okay Colin. I'll give it a try. I have a bunch of different resistors but I'll have to grab a transistor. Just of interest, does the base really need 3v or will a smaller voltage do it. From my readings, am I correct in thinking that the base can be fed with 0.6v to trigger it? Is the base coming from the AC audio output? Also, am I correct in assuming that the collector and emitter are connected to the switch terminals? As you can glean, I'm pretty green! Cheers, Rees. | |
| | #6 |
You are going to need a whole range of components. The base needs a minimum of 0.6v and the 10k resistor and 3v will provide the 0.6v and sufficient current to saturate the transistor. Also, am I correct in assuming that the collector and emitter are connected to the switch terminals? Yes. Try either direction. Is the base coming from the AC audio output? Yes. The base will eventually be driven from the AC signal - via a filter network (a charge-pump arrangement). Last edited by colin55; 4th July 2009 at 11:22 AM. | |
| | #7 |
Okay Colin, many thanks for the clarification and your input. I'll get hold of a general purpose NPN transistor and try and work out how to get sufficient voltage to the base. I have about 1.2v AC coming out of the amp output. Not sure if I can generate any more as it's only a tiny amp. I may have to use a smaller resistor to saturate the base. I haven't calculated the current yet. I'll get back to you after I've experimented. Cheers, Rees. | |
| amp, project, recorder, voice |
| Voice recorder... | Rescue1 | Electronic Projects Design/Ideas/Reviews | 10 | 5th April 2009 06:35 AM |
| !!!NEED HELP!!!add in recorder voice in 18f4520 | caltex | Micro Controllers | 9 | 12th October 2007 07:57 AM |
| Voice recorder without microcontroller | Souper man | Electronic Projects Design/Ideas/Reviews | 10 | 16th June 2007 05:11 AM |
| digital voice recorder | piyush_it1 | Electronic Projects Design/Ideas/Reviews | 5 | 13th March 2006 09:51 AM |
| digital voice recorder | piyush_it1 | Micro Controllers | 1 | 9th October 2005 02:45 AM |
