+ Reply to Thread
Results 1 to 9 of 9
Thread: Creating The N'th Equation Starting Conditions
  1. #1
    Banned transgalactic Bad transgalactic Bad transgalactic Bad
    Join Date
    Apr 2008
    Posts
    240
    http://i44.tinypic.com/2i7o3v6.jpg
    how to solve it.
    i made a differential equation for the first and second periuds
    and i got their starting conditions
    i dont know how to find the starting condition of the ZSR(differential equation) after a long time
    like they ask
    does any body has an idea
    i can post the differential equation of the first an second period if it helps
  2. #2
    MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Im not sure if i understand your question but i'll take a shot.
    It sounds like that when you start your analysis you're ok, but
    when you need to switch equations (when the switch changes)
    you dont know how to figure out the initial conditions for the next
    period.
    If this is the case, the answer is quite simple really. The initial
    conditions of the next period come from the end conditions of the
    previous period...and they are...the same!
    In other words, the current flowing at the time of the last period
    is taken as the initial current in the next period.
    Of course the first period has initial condition of zero.
    If you want to post your equations we can take a look at those too.
  3. #3
    Join Date
    Apr 2008
    Posts
    240
    ok i will copy what i got
  4. #4
    Join Date
    Apr 2008
    Posts
    240
    i dont know how to find the initial conditions
    of time "n"
    in time
    I(L/R)=(-E/R )*e^(-1) + E/R
    I(2L/R)=((-E/R )*e^(-1) +E/R)*e^(-1)
    what now??
  5. #5
    user_88 Newbie
    Join Date
    Nov 2008
    Location
    Texas
    Posts
    413
    I'm used to seeing the Laplace Transforms ...
    Can you write the two LT equations ... for each respective switch state?
  6. #6
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Hi again,
    I see you found out that the charging current starts out at E/R, and
    defining that as Im, for the first half cycle we get:
    i11=Im*(1-e^(-a*dt))
    where
    a=R/L, and
    dt=one half cycle time period
    The second half cycle is discharging, so we get:
    i21=i11*(e^(-a*dt))
    The third half cycle is again charging, only this time:
    i12=(Im-i21)*(1-e^(-a*dt))+i21
    and again the forth half cycle is again discharging, so we have:
    i22=i12*(e^(-a*dt))
    It becomes clear that for odd half cycles the equation is:
    i1=(Im-i2)*(1-e^(-a*dt))+i2 (with initial i2=0 of course)
    and for even half cycles:
    i2=i1*e^(-a*dt)
    Now you can simply keep calculating i1 and inserting into the equation for i2,
    and then calculate i2 and insert that back into the equation for i1, until you
    reach a point where i1 and i2 no longer change, or change very little.
    When you reach that point, you know i1 and i2 are the upper and lower
    limits of the current wave.
    Doing this analytically, we end up with:
    i1=Im*(1-e^(a*dt)+e^(-2*a*dt)-e^(-3*a*dt)+e^(-4*a*dt)-...+...)
    which can be summed up as:
    i1=Im*(1+sum[1 to N][e^(-k*a*dt)*(-1)^k])
    for N the number of half cycles and N is odd, and i1 is the upper limit on the sawtooth.
    You can derive a similar equation for i2, the lower limit on the sawtooth,
    or use the fact that it is centered between Im and 0 amps (which would be Im/2 amps).
    Worked example:
    L=100uH
    R=100 ohms
    dt=10us (each half cycle is 10us)
    square wave with period 20us.
    The upper limit i1 is: 0.00731 amps approximately, and
    the lower limit i2 is: 0.010-i1=0.00269 amps approximately.
  7. #7
    Join Date
    Apr 2008
    Posts
    240
    why you say that "E/R=10ma"
    we are not given E and R
  8. #8
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Quote Originally Posted by transgalactic View Post
    Hi again,
    Yes, sorry, that was a typo. I have corrected that now and it should read:
    "I see you found out that the charging current starts out at E/R, and
    defining that as Im, for the first half cycle we get:"
    instead of:
    "I see you found out that the charging current starts out at 10ma (E/R), and
    The problem came in where i accidentally typed the 10ma from the
    worked example instead of just the more general "E/R".
    There were a couple other typos too that apparently you didnt see because
    i had corrected them already. I believe they are all corrected now.
    Also note that this charging current is not the initial current, just the coefficient
    in the equation which also happens to be the max current that could be obtainable.
    That sure would be magic if E/R always equaled 10ma wouldnt it? ha ha :-)
  9. #9
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,191
    Hi again,
    I just thought i would mention that there is a closed form for that
    series i gave you a while back (a few posts back). Would you
    like to try to find it?
+ Reply to Thread
  1. CST MWS boundary conditions problem?
    By winson in forum General Electronics Chat
    Latest: 17th June 2009, 05:52 PM
  2. 1wire temperature sensor - working conditions 0-300 degrees C
    By arhi in forum Datasheet/Parts Requests
    Latest: 23rd June 2008, 03:42 PM
  3. how do I do this equation
    By north in forum Math and Physics
    Latest: 28th March 2007, 09:34 AM
  4. equation
    By chandu13 in forum Micro Controllers
    Latest: 19th December 2006, 11:08 AM
  5. 3 conditions
    By vxr in forum Micro Controllers
    Latest: 20th September 2003, 11:15 PM
Tags for this Thread
