+ Reply to Thread
Results 1 to 3 of 3
Thread: Confused about very simple things...
  1. #1
    ulg
    ulg is offline
    ulg Newbie
    Join Date
    Jul 2009
    Posts
    6
    Default Confused about very simple things...
    I'll try to be brief, my problem involves interpreting data sheets of components. For example on the data sheet for a SCR I see the following data:
    Min / Typical / Max
    Gate Trigger Voltage (Continuous dc) : 0.4 0.6 0.8
    Now, does that mean I require voltage within those ranges- or can I use the full value of the anode / cathode? For example if it also has a "Peak Repetitive Off−State Voltage" of 600 volt(dc)- can the gate handle that?
  2. #2
    OutToLunch Good OutToLunch Good OutToLunch Good
    Join Date
    Jun 2006
    Location
    North Carolina, USA
    Posts
    355
    due to process variations in the manufacturing process, there will be a range of values for the gate trigger voltage. Basically what that is telling you is to make sure your gate voltage is no less than 0.8V to insure that the SCR will trigger. Statistically, though, most of the triggering will occur at 0.6V for a majority of the SCRs they produce.
    Last edited by OutToLunch; 2nd July 2009 at 12:46 PM. Reason: SCRs don't untrigger :)
  3. #3
    ulg
    ulg is offline
    ulg Newbie
    Join Date
    Jul 2009
    Posts
    6
    Thank you for clarifying that- I was a little worried since a mosfet gate only handles so much voltage. Mechanical DPDT relays are a killer on budgets and I would like to put an end to that not to mention the solid state benefit.
+ Reply to Thread
  1. :confused:Capacitor Advice:confused:
    By Memphis_Raines in forum General Electronics Chat
    Latest: 5th December 2009, 07:46 PM
  2. :confused:Help in numeric keypad concept.:confused:
    By xxxnonoxxx in forum Micro Controllers
    Latest: 25th May 2007, 01:07 PM
  3. Any Things That U Know About G LCD
    By eddy_eclectic in forum Datasheet/Parts Requests
    Latest: 4th July 2005, 06:41 AM
  4. Confused about simple electrical safety concept (pics)
    By chson in forum General Electronics Chat
    Latest: 29th March 2005, 10:00 AM
  5. Two things?
    By Scarr in forum Micro Controllers
    Latest: 22nd July 2003, 10:07 PM
Tags for this Thread
