Old 1st July 2009, 11:50 PM   #1
Default antennas and standing waves
I'd like to have a better understanding on some RF stuff...
i know a miscalculated antenna has standing waves which is lost energy because the antenna radiates badly... standing waves can harm the output
stage of an amplifier.
i need to know if standing waves are related with impedance mismuch between the antenna and the amplifier so depending the output power there is a posibility the amplifier to get damaged from excesive current draw.
i also need to know why the antenna must be the size of the wavelength or subdivisions of it? i don't exactly understand why the wave must travel its length or subdivision of it's length on the wire before it gets radiated..
thanks!
whiz115 is offline
Old 2nd July 2009, 12:24 AM   #2
Transmission lines and antennas are governed by a partial differential equation called the wave equation that depends on the three spatial variables and time. The PDE and the boundry conditions allow for only certain kinds of solutions. A standing wave is the part of the solution that depends only on position and not on time. A traveling wave is the part of the solution that depends only on time and not on position. The combined solution is the product of the two solutions. Since each solution happens to be an exponential, the product of exponentials is an exponetial with an exponent that is the sum of the exponents of the individual solutions. This happens when separation of variables is used.
When waves encounter an impedance discontinuity at least two things happen. Part of the energy in the wave is reflected back toward the source and part of the energy continues on it's way.
The geometry of quarter wave and half wave antennas falls out of the boundry conditions to the PDE.
We never have time to do it right; but we always have time to do it over.
Papabravo is online now
Old 2nd July 2009, 12:41 AM   #3
Standing waves are indeed a direct result of a mismatch between an antenna and the amplifier. The standing wave is the pattern you get (in voltage or current) when the power travelling to the antenna is superimposed on the power reflected back from the antenna due to mismatch of antenna and transmission line. Power is travelling in both directions at once and when you sum the instantaneous voltage at all points along the line you get a steady pattern of highs and lows. This is the "standing wave".
There are three parts to the problem...the amplifier, the transmission line and the antenna. If the antenna is not matched to the transmission line's impedance then it will reflect some power back to the source. If the amplifier is matched to the transmission line inpedance, then all of this reflected power gets absorbed by the amplifier, which means it has to deal with heat. At the same time, since the amplifier is seeing a mismatch, then yes its current may be higher than it is supposed to be, and efficiency will be lower than it is supposed to be and it heats up, possibly to destructive levels.
Your question of why the antenna must be large relative to the wavelength is a big one and there are whole books written to explain it. However, perhaps a short answer might help. In fact, an antenna does not have to be a significant multiple of a wavelength to function. Many practical antennas are much smaller than one quarter wavelength For example, the short loop is a very common but very small antenna that is used in many places. For example, many garage door opener remotes use such antennas.
Anything can be used as an antenna, its a matter of how well you want it to work. Fifty years ago it was pretty much the rule that any antenna you would run across was indeed large, like quarter or half wavelength. But with the march of technology and the development of so many portable and mobile devices, antenna designers have found that it is often better to simply settle for less performance for the sake of small size.
Theory says that you can make an antenna infinitely small and still achieve good radiation performance if you can do two things. One is that you have to find a way to have lots of current flow in your antenna and the other is that your antenna cannot have any resistive losses at all. Unfortunately, both of these "gotchas" are major roadblocks. It is quite difficult to get a lot of RF current to flow in a very short wire (unless it is a loop) and it is almost impossible to remove all the resistive losses in an antenna. So, in practice, very small antennas are difficult to impedance match to an amplifier, and even then, they are very inefficient radiators (and also have very narrow bandwidth which is an additional difficulty). Most industries that can afford the room have learned to use larger antennas to avoid these problems.
RadioRon
RadioRon is online now
Old 2nd July 2009, 01:22 AM   #4
really helpful responses.. but...
reflected energy must be standing waves right?
the main reason for standing waves is impedance mismatch?
i need to know if you too mean impedance mismatch or any other kind of mismatch.
whiz115 is offline
Old 2nd July 2009, 01:43 AM   #5
The main reason that reflections happen is impedance discontinuity. We know that in a properly terminated transmission line there are no reflections, because there are no impedance discontinuities. Any degree of mismatch allows a standing wave to exist.
Old 2nd July 2009, 02:16 AM   #6
ok...
how antenna impedance gets created? i guess impedance is a result of inductance and inductance a result of antenna mechanical characteristics..
if that's true how come there are antennas for different transmission frequencies 2.4GHz and 5GHz with the same impedance? for a example
if i would like to make a simple telescopic antenna for 2.4GHz i would make one having the size of the wavelegth i need to emit... how do i know if i have 50Ω impedance or whatever?
also i haven't understood the role of the antenna length relative to the wavelength.
whiz115 is offline
Old 2nd July 2009, 03:06 AM   #7
Lets try a few simple explanations.
The antenna provides a means of coupling electro-magnetic waves (energy) into and out from free space.
Mathematicians and physicists tell us that the impedance of free space is 377 ohms.
As well as coupling the energy, the antenna effectively makes an impedance transformation between its feedpoint and free space.
A halfwave centre fed dipole will have a feedpoint impedance of 75 ohms irrespective of its design frequency.
A folded dipole will have a feedpoint impedance of 300 ohms irrespective of its design frequency.
A quarterwave monopole above a large groundplane will have a feedpoint impedance of 35 ohms irrespective of its design frequency.
The feedpoint impedance is a property of the physical arrangement of the antenna.
Almost all antennas have standing waves on the radiating elements, (there are a few odd exceptions such as the rhombic). The problem with standing waves comes when they are in the feeder from the transmitter to the antenna, they are caused by an impedance mismatch between the antenna and the feeder. If a 75ohm dipole is connected to a 50ohm feeder, there will be a mismatch which causes standing waves in the feeder. This in itself is not the end of the world, but if the feeder were connected to a transmitter which required a accurate 50 ohm load for correct operation, there would be problems.
If we connect our 75ohm dipole to a 50ohm feeder, there will be a VSWR (Voltage Standing Wave Ratio) of 1.5 to 1 in the feeder.
What this means is, if we measure the voltage at various points along the feeder, we will find alternate maxima and minima at quarter wavelength intervals along the feeder, the ratio of the maximum to minimum voltage will be 1.5 to 1.
Enough for now, bedtime I think.
JimB is offline
Old 2nd July 2009, 03:42 AM   #8
A forum post can only go so far. You really need to find a good reference and acquire enough background so that the explanations we've given start to make sense. Without sufficient background we can talk until we are blue in the face and you won't have any better idea of what is going on. What did you expect exactly? That the concepts were easily explained and understood; I guess I have to apologize for the level of disappointment you must be experiencing. I've given you the best advice I have; I can't do any more.
Old 2nd July 2009, 08:43 PM   #9
why bother saying these?! no need... you did whatever you could to answer my questions right? thank you guys!
whiz115 is offline
Old 2nd July 2009, 10:47 PM   #10
If you want to learn a bit further, here is a very good explanation of why an antenna actually radiates:
ARRLWeb: Why an Antenna Radiates
RadioRon
Old 3rd July 2009, 11:31 PM   #11
i have a small one transistor FM transmitter and today i decided to experiment a bit...
i was using the transmitter without any microphone connected... and i was trying to find the carrier frequency on the radio which was difficult because the transmitter is unstable and the frequency was rolling...but i got surprized when i noticed that if i hit a component with the back of the screwdriver then i can hear the noise from the radio like if i was recording the sound.
my opinion is that the vibration was transformed into electrical signals which then transmitted to the radio...and probably the variable capacitor was responsible for that effect... the sound has nothing
to do with bad conduction..
what do you think?!
whiz115 is offline
Old 4th July 2009, 12:33 AM   #12
so...antenna impedance is a property of the antenna type?!
can you show me a feedpoint, a feeder and a dipole? although i know what these are...you're getting me confused because i don't know what you mean when you say to connect a 75ohm dipole to a 50ohm feeder.
whiz115 is offline
Old 4th July 2009, 02:00 AM   #13
what do you think?!
Yes, you are right. In this case we say that the circuitry is "microphonic".
RadioRon
Old 4th July 2009, 02:33 AM   #14
so...antenna impedance is a property of the antenna type?!.
Yes, as I said previously, a halfwave centre fed dipole has an impedance of 75ohms, etc. Some practical antennas will have matching circuits built in them to give other impedances (usually 50 ohms).
A dipole has two wires (or rods), each wire is a quarter wavelength long at the design frequency.
This dipole will have an impedance of 75 ohms.
As the two wires are the same length the dipole is centre fed, this is the feedpoint of the antenna.
The feeder is the cable which connects the transmitter to the antenna.
Most often the feeder is a coaxial cable, sometimes the feeder can be what is known as "twin feeder" which is basically two parallel wires.
Coax and twin feeder have characteristic impedances.
Coax usually 50 or 75ohm, and twin feeder 75 or 300 ohm. Other values are available but these are the most common.
The impedance of a coax cable depends on the ratio of the diameters of the centre core and the braid and the dielectric material between them.
The impedance of a twin feeder depends on the diameter of the wires, their spacing, and the dielectric between them.
See the attached sketch to help your understanding of the terms.
JimB is offline
Old 4th July 2009, 06:53 PM   #15
excellent... i think i have a better understanding concerning RF than i did before..
i'm using a 15'' hook up cable for antenna and i would like to know how it radiates in my room (how the electromagnetic field looks like around the cable
and inside my room while the antenna is looking horizontally over my desk)
what type of antenna is the cable i'm using and what's the impedance of it and of the FM transmitter
It is based on a 2n3904 transistor and i'm using a 9V battery source and it draws about 20mA so it decipates about 180mW and the output RF power must be ~50mW so the output power in dB must be +17dBm but what's the signal level in μV that reaches my radio at a distance of 5 meters?!
whiz115 is offline
antennas, standing, waves
Barely standing? LIES dknguyen Robotics Chat 17 9th December 2007 09:42 PM
RF antennas Asjad General Electronics Chat 8 28th October 2004 06:06 AM
compare standing wave forms with traverling waves bully_victim General Electronics Chat 0 13th November 2003 10:08 AM
square waves into sine waves... any ideas???? bully_victim Electronic Projects Design/Ideas/Reviews 9 10th November 2003 05:46 PM
