+ Reply to Thread
Results 1 to 6 of 6
Thread: Active and passive ??
  1. #1
    Anki Newbie
    Join Date
    Jun 2009
    Location
    Maharashtra
    Posts
    8
    Smile Active and passive ??
    Hey plz tel me about active and passive components. . . .m really confused between the two
  2. #2
    alphacat Okay
    Join Date
    Apr 2009
    Location
    France
    Posts
    735
    To the best of my knowledge, a device is considered active if:
    1. its a power source.
    2. it amplifies current or voltage signals.
    3. it behaves like a switch, meaning it has states that are equivalent to ON and OFF.
    I'd like to hear too about that issue (also about passive components).
  3. #3
    smanches Excellent smanches Excellent smanches Excellent smanches Excellent smanches Excellent
    Join Date
    Mar 2009
    Location
    Oregon, USA
    Posts
    886
    In the most basic terms, active components change their behavior based on the signals they interact with (diodes, transistors, etc.) Passive components behavior is not changed by the signals going to them (resistors, capacitors, etc).
  4. #4
    MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,286
    Hi Anki,
    The most exact definition says that an active device is one that generates
    energy in the circuit, but then we can ask the question of where that energy
    came from in the first place, and then several other devices dont actually
    generate anything but they do regulate energy so it seems like they should
    be called active too. Still yet other devices convert energy...should they
    be called active too?
    So dont feel too bad, because lots of people and web sites are also confused.
    The reason why is because how you classify a given element depends partly on
    how you are analyzing it. Most classify resistors as passive, but that's about the
    end of it.
    One saving grace is to not worry so much about what is active and what is
    passive. Just forget about this for now. Instead, concentrate on each
    element you know about, taking one at a time, until you know a lot about
    that one, then move on to the next. Of course start with the resistor and
    battery.
    Once you get a feel for how several devices work you can make your own
    judgment about what is active and what is passive. You will find that the
    definition varies a bit.
  5. #5
    Anki Newbie
    Join Date
    Jun 2009
    Location
    Maharashtra
    Posts
    8
    Hey thanks a lot. . .
  6. #6
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,003
    Passive parts are considered to be capacitors, resistors, and inductors, and their value, to a first approximation, is constant. They do not require any added power to perform their function.
    Active devices usually contain semiconductors, (tubes in the olden days) which modify the signal in some manner (switch on/off, gain, non-linear wave shaping, etc.) that requires some form of added power.
    Carl
    Curmudgeon Elektroniker
+ Reply to Thread
  1. active vs passive sensor
    By fedail in forum General Electronics Chat
    Latest: 11th January 2009, 12:32 AM
  2. Passive & active filters
    By maidmarion in forum General Electronics Chat
    Latest: 9th March 2008, 01:34 AM
  3. Active High and Active Low
    By Badar in forum General Electronics Chat
    Latest: 28th August 2007, 01:05 AM
  4. passive/active RF for door lock/unlock (schematics? urls?)
    By kiko187 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 26th February 2004, 07:36 PM
  5. Active Crossover vs Passive Crossover
    By johneppen in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th March 2003, 12:48 AM
Tags for this Thread
