| I need to build a 16.1V buck boost That can handle a Voltage input anywhere from 18.5 to 9 V and current anywhere from 100 mA to 7A is this possible to make with high efficency? Let me know if you have a circuit terramir | |
| :cry: please does someone know of a buckboost circuit that could help me here? I really need some help terramir | |
| I mean, better to do this in two steps: build a boost converter with 36V output, and another buck 36V to 16.1V (L4970A from STmicro) | |
| Sure you can! There's the Cuk converter, which unfortunately creates only negative voltages, so you'd probably cascade the buck/boost converters together. Efficiency is limited. You can use a MOSFET in place of the flyback diode (if your chip supports it) and save part of the voltage drop losses there. But copper & core losses in the inductors leave you in the range of 80%-90%. Losses are lowest when when your ratio is 1:1 and gets higher from there. Unfortunately, getting losses down requires a lot of very specific knowledge of inductors and detailed specifications on the inductor core you've got, so count on the low end, maybe 70%. I had did this with the PIC, by the way. 7 amps will require some pretty sizable inductors. | |
