+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 23 of 23
Thread: About laser emitter and receiver
  1. #16
    honggexjq Newbie
    Join Date
    Jun 2009
    Posts
    11
    Quote Originally Posted by Mr RB View Post
    Definitely not from a hobby level device. Even the very expensive pro devices have a few mm error which they try to average out over time by taking a longer reading.
    Is there any reason you want to use a sinewave??
    hi,the 1mm error is not a strict requirement and if i can make a sample device with a 10mm error,that'll be OK.
    I decided to use a sinewave cuz i want to use the phase-shift method to measure the distance.Can you give me some advice if a loose error requirement is allowed?
  2. #17
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    Quote Originally Posted by honggexjq View Post
    Can you post your phase shift measurement circuit.?
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  3. #18
    honggexjq Newbie
    Join Date
    Jun 2009
    Posts
    11
    Quote Originally Posted by ericgibbs View Post
    sorry, but now i'm only at the emitting and receiving stage,and haven't reached the following phase-detect stage yet.Anyway,the basic idea is to measure the phase shift between the emitted sine wave and the received sine wave.As you can see,my first mission is to produce a sine wave and then capture an acceptable sine wave
  4. #19
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    OK.
    How do you plan to construct the TX module.?
    Is the TX module going to be moving or stationary?
    Also can you say what the target that reflects the laser beam will be.
  5. #20
    honggexjq Newbie
    Join Date
    Jun 2009
    Posts
    11
    OK.
    TX module is stationary and the target is some plant.
  6. #21
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    Reason for asking is to determine if the target is 'cooperative'
    example: a retro prism or reflector or is it non cooperative.?
    I'm not sure what you mean by 'plant', in English that could mean a piece of equipment??
  7. #22
    honggexjq Newbie
    Join Date
    Jun 2009
    Posts
    11
    haha,sorry for my poor english.By saying plant i mean those with leaves,like grass.So it's non cooperative.
    maybe someday i should practice my english with a native like you
  8. #23
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    Your English is just fine.
    A point to note is that when working with non cooperative targets, the strength of the echo signal can effect the apparent range.
    This is partly due to the rise times of the receiver circuits.
    If you examine the response curves for your receiver amplifiers you will see that for low signal levels the 'time' response is not linear.
    This means that strong echo's appear to have a shorter overall response time which makes the measured distance shorter.
    Do you follow.?
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Long Range Infrared Emitter circuit & receiver
    By Team PSU in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st December 2009, 07:43 PM
  2. Distance between Receiver and emitter (RF)
    By Sync in forum Electronic Projects Design/Ideas/Reviews
    Latest: 3rd June 2008, 03:04 PM
  3. IR Emitter/Receiver for Line Following Robot
    By Nayyi in forum Electronic Projects Design/Ideas/Reviews
    Latest: 19th August 2007, 06:41 PM
  4. IR Emitter / Receiver / Detectors ... need help
    By micro571 in forum General Electronics Chat
    Latest: 14th December 2004, 02:13 AM
  5. n00b needs advice: Infrared Emitter and Receiver
    By Shion Uzuki in forum General Electronics Chat
    Latest: 3rd June 2003, 06:27 AM
Tags for this Thread
