Old 28th June 2009, 03:41 PM   #46
Originally Posted by DirtyLude View Post
You must be doing some pretty large boards to need a bucket. 20cm is about as large as I've ever needed, so I just use a plastic sandwich container. For the FC etchant, I would shine a light underneath, which would warm the etchant and also I'd be able to see when the etching was complete, because I could see through the board.
I don't see any benefit to the plastic bag and I can see it being a mess.
Ya, I have one bottle of FC and one bottle of AP crystals that I'll never use.
Here's a tip. Don't sniff the muriatic acid, like I did. That'll wake you up.
I have an ultrasonic cleaner that will accommodate an object as large as a CD. I tried to figure out how to use it as an etcher. The bowl is SS so I cant poor the etchant into it directly. But if I use the plastic bag method then I can put it into the cleaner. I would first put a strong mixture of baking soda and water in the bowl as a safety measure.
What do you think, please comment.
Rolf is offline
Old 28th June 2009, 03:55 PM   #47
It sounds like a good idea in that getting fresh etchant to the copper is what works.
I wonder if the ultrasonic cleaner will remove the toner too ?
BCHS/3v0's Tutorials
3v0 is online now
Old 28th June 2009, 04:38 PM   #48
Good point! Just ran a 15 minute test in water, it loosened some of the transfer paper on one design. The other design was clean already. None of the traces on either design was effected after the cleaner ran for two spurts of 8 minutes each. So I don't think there is anything to worry about. Guess I will have a go of it for my next board.
P.S. I know 8+8=16 but I had the PCB out several times for inspection without stopping the US timer.
Rolf is offline
Old 28th June 2009, 04:45 PM   #49
Did that the first time. And it did wake me up.
I heard the AP was good also and was going to try it. But this does work quite well over Ferric Chloride. Will hang on to the FC for a couple more months and put it on Craigslist to get rid of it.
I was hoping Rolf would try hair spray, the glue stick looked pretty good.
Maybe I will skip AP and try the Pulsar paper next.
mramos1 is offline
Old 28th June 2009, 05:11 PM   #50
I will try that on my next board. I have a 2.5 liter ultrasonic cleaner (clean carbs in it). Stainless like yours. I was using plastic cups too, maybe I will set a cup in the cleaner and see how fast the copper comes off and pray it does not remove toner Mine heats as well.
Last edited by mramos1; 28th June 2009 at 05:13 PM. Reason: Oh the cleaner removed the coating, I thought you met while ecthing, will try both.
mramos1 is offline
Old 28th June 2009, 05:36 PM   #51
Sounds like a good idea. Going to have to check ebay for something large enough for a 4BBL.
3v0 is online now
Old 29th June 2009, 03:14 AM   #52
I think a gentle rocking of the etchant tank would do better to agitate the etchant than an ultrasonic cleaner. If I did anything, I might make up a small platform with a servo, but as it is, just knocking the board about a bit with the end of a plastic clip seems to work fine, especially with the acid etchant, which doesn't really need much in the way of agitation.
Mark Higgins
DirtyLude is offline
Old 29th June 2009, 03:25 PM   #53
I think a gentle rocking of the etchant tank would do better to agitate the etchant than an ultrasonic cleaner. If I did anything, I might make up a small platform with a servo, but as it is, just knocking the board about a bit with the end of a plastic clip seems to work fine, especially with the acid et chant, which doesn't really need much in the way of agitation.
"I think a gentle rocking of the et chant tank would do better to agitate the et chant than an ultrasonic cleaner"
Is this just a guess? I don't like to play games so I am going to find out for myself, unless someone that have actually tried it post their experience.
Meanwhile, I will stick with my turkey basting method, it works fine.
Rolf is offline
Old 29th June 2009, 04:20 PM   #54
When I say "I think" it means it's just a guess. But I still don't see the point. Is it not etching fast enough for you?
Mark Higgins
Old 29th June 2009, 04:25 PM   #55
I etch in a glass bread pan. I set the pan on a block of foam rubber. A little down pressure on the pan is enough to rock the fluid. Works. I expect the turkey baster is faster.
It would be nice to add a heating pad or such to keep the etchant hot.
This is not my idea of the ultimate etcher but it works well for single boards.
3v0 is online now
Old 29th June 2009, 04:35 PM   #56
I think you can judge the speed by observing the color of the copper. When I squirt the board it immediately turns a bright and shiny. I cant remember getting that when I just rocked it back and fourth.
It takes about 15 min at room temp.
Rolf is offline
Old 29th June 2009, 07:37 PM   #57
Works very well, if I can do boards in it, better. And I brought the extended warranty so I will use it a lot more. No 4barrel in this one. Almost. You can clean and flip and clean, that works too.
mramos1 is offline
Old 30th June 2009, 05:20 AM   #58
Default Use a sponge or pad
over at the Pulsar site they suggest using a soft sponge or pad and gently wiping the boards while etching
with gloves on of coarse.
and safety glasses
if using the muratic acid / hydrogen peroxid method its
1 part muratic acid in first
THEN
add 2 parts hydrogen peroxide
have seen reference to this. do not reverse where you add the acid to the hydrogen peroxide.something about chemistry??
adding a base to acid??? is the proper procdure
double check first.
MrDEB is offline
Old 30th June 2009, 05:31 AM   #59
I etched My first board so far so good I used photo paper and the old lady's iron to iron it on first try I didn't get all of it on the copper second time it came out fine I think I'm going
to like this Lol.
be80be is offline
Old 30th June 2009, 05:39 AM   #60
"I think a gentle rocking of the etchant tank would do better to agitate the et chant than an ultrasonic cleaner"
Well how about an educated guess... Everything about ultrasonic cleaners is optimised to focus all the power on removing stuff from surfaces... It may not be the best agitator for an etchant tank.
Mr RB is offline
cheap, diy, easy, paper, toner, transfer
Toner Transfer PCB... Possible on this? Franknstein Electronic Projects Design/Ideas/Reviews 31 11th November 2009 10:13 PM
PCB toner transfer Badar General Electronics Chat 58 16th July 2009 02:40 PM
Toner Transfer paper, UK HerbertMunch General Electronics Chat 15 1st December 2007 04:01 PM
toner transfer with silicone impreg paper justDIY General Electronics Chat 28 13th March 2007 11:33 PM
toner paper nye Electronic Projects Design/Ideas/Reviews 8 27th October 2006 10:23 PM
