| | #31 |
| | #32 |
| Simple, don't bake it then. Why would you bake it?
| | #33 |
| | #34 |
| | #35 |
| Oh, you mean iron it, yes fair point but you don't have to use the highest heat setting do you
| | #36 |
| | #37 | |
P-n-P recommends 300°F +/- 25°F, So I set my iron to 300°F with a thermocouple thermometer. That happens to be between wool and cotton on my iron. | ||
| | #38 |
| | #39 |
I tried the Muriatic Acid/Peroxide etchant today and it worked well. I think I'm going to stick with it.
__________________ Mark Higgins | |
| | #40 | |
When I did my first board with water, the waste was blue (1/3 1/3 1/3), without the 1/3 water, it seems to turn green. Either way it works. Now I have 7 bottles of Ferric Chloride and a bag of the powdered version I will probably never use. I have not tried doing them in a zip-lock plastic bag yet. But next ones I will try that method. | ||
| | #41 |
never thought about doing it that way. problem is the bag size needs to be large. I myself use a plastic tub like what ice cream came in. even considered using a "kitty litter box" but would need lots more chemical. my vote is for the hydrogen peroxide/muratic acid this wax paper thing not real sure about. go-na have to try it out | |
| | #42 | |
I use a turkey baster to squirt the acid on the board which I have placed face up in the tray. The laser label backing paper is better. Last edited by Rolf; 28th June 2009 at 01:38 PM. | ||
| | #43 |
I have only done the bag thing with sodium persulphate which is much safer to handle. Make sure you use the freezer zip lock bags. The others are not strong enough and will leak. Even so I am not sure if it is a good idea.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #44 | |
![]() The top right side did evidently not have enough glue on it. Last edited by Rolf; 28th June 2009 at 03:46 PM. | ||
| | #45 | |
You must be doing some pretty large boards to need a bucket. 20cm is about as large as I've ever needed, so I just use a plastic sandwich container. For the FC etchant, I would shine a light underneath, which would warm the etchant and also I'd be able to see when the etching was complete, because I could see through the board. I don't see any benefit to the plastic bag and I can see it being a mess. Quote:
Here's a tip. Don't sniff the muriatic acid, like I did. That'll wake you up.
__________________ Mark Higgins | ||
| cheap, diy, easy, paper, toner, transfer |
| Toner Transfer PCB... Possible on this? | Franknstein | Electronic Projects Design/Ideas/Reviews | 31 | 11th November 2009 10:13 PM |
| PCB toner transfer | Badar | General Electronics Chat | 58 | 16th July 2009 02:40 PM |
| Toner Transfer paper, UK | HerbertMunch | General Electronics Chat | 15 | 1st December 2007 04:01 PM |
| toner transfer with silicone impreg paper | justDIY | General Electronics Chat | 28 | 13th March 2007 11:33 PM |
| toner paper | nye | Electronic Projects Design/Ideas/Reviews | 8 | 27th October 2006 10:23 PM |
