| | #196 | |
The Result : print on the copper board was just a little better than before but a small portion in the middle just swelled up(and detached form the board) & WASTED .. ![]() Conclusion: at max temperature, using 1000w iron , only 3-4min will do the job
__________________ Rεσllγ !!! Mγ Σ×ρer!ence is Directly Propotional τΘ the NΦ of Electronic Items I have Me§§eD µρ . .. Last edited by tariq7868; 7th August 2009 at 07:04 PM. | ||
| | #197 | |
If you dont have a thermometer set the iron between acrylic and polyester to start with. Remembering back to my experiments; the wax paper had a good side (and a bad), I think it was the duller of the two sides that worked best. | ||
| | #198 |
| Actually there's no hard and fast rule: it depends on the toner's melting point.
| | #199 |
| | #200 |
I run the iron all the way up and iron for 3+ minutes and it always works well. Will check temp next time and see what the iron runs.
| | #201 | |
So I will start: I use a HP printer and it works great at <3min at 300°F. We are of cause talking about toner transfer using an iron. | ||
| | #202 | |
Tried the laminating machine as well, took too many passes when the iron does it in minutes. | ||
| | #203 | |
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #204 | |
I can't stomach all the ambiguity in information on the Pulsar site, and I only saw one reference to temperature, 275°F. They are in essence jut pushing their laminator sales and we are talking about using an iron. If it is large difference why don't they publish the fact? In other words the temp. required for each brand of printers. Time and temperature are major components of this process and we need reliable information to get good repeatable results. | ||
| | #205 |
Rolf have you seen this page ? PCB "Fab-In-A-Box" ... The 8min circuit board system Look for This is more useful then a table of toner temperature setting. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #206 | |
"The main problem with using an iron is that it is not a well controlled heating device and pressure applied can be a total variable from person to person, so we're going to have you calibrate your iron specifically for your weight! Yes, you are going to be applying your entire body weight to the iron and that will now change the this 'variable' into a 'constant'." | ||
| | #207 | |
Looks like there is more then plenty of BS here too. Quote:
In the real world it does not much matter if what one writes is true or not. If enough people spread enough bull others will take it as fact. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
| | #208 |
toner used in photocopying took almost double the time in transferring than the toner used in hp P1006 laser printer
__________________ Rεσllγ !!! Mγ Σ×ρer!ence is Directly Propotional τΘ the NΦ of Electronic Items I have Me§§eD µρ . .. | |
| | #209 |
| | #210 |
To add to the confusion. I crank my iron to the max when using the photo paper, but apparently this is too hot for Pulsar paper and gives me squished lines. I don't know the specific iron temp and I have not tried the Pulsar paper again using lower temps, yet. So, the useful temperature may not only be based on the toner you are using, but the 'paper' you are using as well.
__________________ Mark Higgins | |
| cheap, diy, easy, paper, toner, transfer |
| Toner Transfer PCB... Possible on this? | Franknstein | Electronic Projects Design/Ideas/Reviews | 31 | 11th November 2009 10:13 PM |
| PCB toner transfer | Badar | General Electronics Chat | 58 | 16th July 2009 02:40 PM |
| Toner Transfer paper, UK | HerbertMunch | General Electronics Chat | 15 | 1st December 2007 04:01 PM |
| toner transfer with silicone impreg paper | justDIY | General Electronics Chat | 28 | 13th March 2007 11:33 PM |
| toner paper | nye | Electronic Projects Design/Ideas/Reviews | 8 | 27th October 2006 10:23 PM |
