Old 11th July 2009, 03:16 PM   #136
You have Ferric Chloride. Do not inhale the fumes and it stains everything. Will take the chrome off of plumbing fixtures.
BCHS/3v0's Tutorials
3v0 is online now
Old 11th July 2009, 03:53 PM   #137
Originally Posted by be80be View Post
Magazine paper is the same thing as Presentation Paper they sell it at office max
it comes off easier then the photo paper.
sand paper i clean copper pipe with it 220. I'm going to get some 600 to day
etchant? I don't no what it has in it I got it at radio shack it looks like oil.
I have never used anything but a metal polish.
If I used sand paper It would properly be 1200 grit!
Like I have written before, if the copper is shiny it is clean. Run water over it for a last check, make sure the water is not beading.
I use an old stash of Revere Ware copper cleaner but it is unfortunately not available any more. But most any metal or brass/copper cleaner/polish should be able to do the job. Brasso is a name that comes to mind.
In many cases the copper oxide layer is so thin that a plain pencil eraser will take it off, so it seems to me that using sand paper is a gross overkill.
Rolf is offline
Old 11th July 2009, 04:00 PM   #138
Warning do not use in basement. It's hard on you should be on the bottle. And i have ventilation.
be80be is offline
Old 11th July 2009, 04:13 PM   #139
Warning no not use in basement. It's hard on you should be on the bottle. And i have ventilation.
I told you not to inhale the fumes. It attacks the lungs and you will get what feels like a chest cold.
3v0
3v0 is online now
Old 11th July 2009, 04:28 PM   #140
It's ok I didn't see that till after. Last time i open the garage door to do this. This time i didn't ! But you could get hurt with this stuff if not real careful
that's why I posted.
be80be is offline
Old 11th July 2009, 07:51 PM   #141
I will look for some next trip to the office depot. I use picture paper (hammermill brand) and I guess it is between what you used and photo paper, photo paper is a pain to get the coating off. Picture paper, you can use your thumbs and get it off with a small amount of work.
I tried hero999's idea "way" back but found the rags in the US are thick and thin and some crumbled up in the printer. As no one new exactly what magazine to use (different areas in the world). Though playboy I think was brought up and I had none of them.
So this looks like something to try. As for the FC, turns have I have 9 bottles of it I will never use again. I will only use the pool acid and peroxide). Much faster and less bad things to breath for me.
Anyone in S.E. Florida that needs come ferric chloride PM me.
mramos1 is offline
Old 11th July 2009, 08:06 PM   #142
Default YES on the muratic acid/hydrogen peroxide
as for cleaning Pulsar recommends using scotch-brite pads.
I myself like 600 wet/dry under running water.
comes out very bright and smooth.
also learned that the lighter boards (1/2 oz) are best.
been using 2oz boards but takes forever and the boards are thick so light doesn't shine through it (helps in locating any bad traces)
MrDEB is online now
Old 11th July 2009, 08:46 PM   #143
I don't know what weight my copper clad board is. I bought it from Maplin's and it wasn't specified.
Thicker copper might take longer to etch but the lower resistance of thicker boards is important for high current stuff.
if I know the answer.
Hero999 is offline
Old 11th July 2009, 09:46 PM   #144
Good point on the thicker copper.
When I read "so light doesn't shine through it" I assumed the fiberglass board during etching. Did not think about the copper layer and thickness.
mramos1 is offline
Old 11th July 2009, 10:13 PM   #145
Originally Posted by mramos1 View Post
And you print on the back side of it?
The backside of my label paper is very different then the slippery surface to which the labels were attached. If that is the case you want the front side after the labels come off.
I used to use this method for printing the silk screen.
3v0
3v0 is online now
Old 12th July 2009, 12:19 AM   #146
Originally Posted by MrDEB View Post
mix up a water starch solution (heavy on the starch) then dip the paper into the solution.
allow to completely dry
then try a toner transfer.
maybe add some cornstarch to mix?
OR
use rubbing alcohol instead of water. would dry faster.or a mixture of rubbing alcohol/water??
It is your idea, we'll let you try it first!
Let us know how it works out.
Rolf is offline
Old 12th July 2009, 12:51 AM   #147
There is another factor. The heavier the copper is the longer it takes to etch and the more it will undercut traces. Not a problem with heavy power traces but bad news for very fine line.
3v0
3v0 is online now
Old 12th July 2009, 01:08 AM   #148
If it works, I'd do a bunch of sheets at one time and store them. I would not want to wait for them to dry each time. I like Eagle Cad to product in hand in 1 hour. I have that now on a simple low parts count board.
When I have time, I will try the presentation paper (Hero999's rag idea from way back as I'm now told is presentation paper) and see if it's better than what I use. I had mixed luck with thin rag paper jams.
My delay in the whole process is getting the paper gloss coating off the copper. Currently I rough up the back of the paper with a plastic brush after a short dip (less that 30 seconds) in warm water, re-dip in warm water and that does it for me in a couple minutes. But I would like to have it fall off, a rinse and go. No rub over a couple time to make sure all that coating came off the toner.
If Pulsar paper person wants to send me a sheet I will give an honest review (and yes I have tried the PnP many years ago).
What I do works well enough. And it sounds like they (Pulsar) takes it to another level. I do not need my boards to look like they are manufactured. But still game to see if their transfer paper is better than what I do now.
Man, if I came here from the outside on toner transfer to PCB I would be here for a day reading with all the posts, thank God I do not need a grid tie hookup.
mramos1 is offline
Old 12th July 2009, 01:15 AM   #149
3v0
Another good point. I make my power traces wider on the boards. Nothing I do is really high power though. If I needed higher power I could solder over the traces and leave a big pad for a heavier gauge copper wire going to what I need.
mramos1 is offline
Old 12th July 2009, 02:58 AM   #150
Default Yes the heaver boards take a long time
even takes longer to get hot enought for the transfer in the laminiator.
To cut down on etching I have been filling all the unused areas so they won't etch.
just put large spaces between traces and filled areas.
MrDEB is online now
cheap, diy, easy, paper, toner, transfer
Toner Transfer PCB... Possible on this? Franknstein Electronic Projects Design/Ideas/Reviews 31 11th November 2009 10:13 PM
PCB toner transfer Badar General Electronics Chat 58 16th July 2009 02:40 PM
Toner Transfer paper, UK HerbertMunch General Electronics Chat 15 1st December 2007 04:01 PM
toner transfer with silicone impreg paper justDIY General Electronics Chat 28 13th March 2007 11:33 PM
toner paper nye Electronic Projects Design/Ideas/Reviews 8 27th October 2006 10:23 PM
