Hi!. Today I've reincarnated an old "Osciloskop MA 4060" oscilloscope with vacum tubes. As far I can see I can tell that it is working, got a stable `dot`. It has 2 inputs by N-female connectors one for X and one for Y. When I connect a signal (doesn't matter the type just to be AC) to X-Input which has for example 5Hz I see a dot that goes left and right 5 times a second. Same happens when I connect the signal to the Y-Input but the dot goes up and down. My question is, how do I need to connect the signal so that I can see it in `real mode`. I mean if I connect a sine wave signal to it, I want actually to see the wave on it. I assume that I'm missing the time base or some time factor ... Thanks in advance ! | |
There should be a switch somewhere on the scope to select x-y or timebase mode. If you can't find it, post of pic of the scope, and I'll see if I can. Egads! Guess I'm showing my age by answering!
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. Last edited by BrownOut; 25th June 2009 at 08:24 PM. | |
There is no timebase mode ... nor a switch for modes ![]() ![]() This is a picture found on the net. I'll take a picture of it tomorrow and post it in a bigger resolution. | |
Look at the timebase rotary switch. It might have a position for x-y.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
As far as I can remember there was no such thing... Will check it tomorrow and give it a closer look. Anyhow, if it doesn't have that switch and its in x-y only mode, is there anything to be done with it ? | |
| | #6 |
There has to be a switch. We just need to find it.
| | #7 |
I hope there is ... I remember I twisted all the buttons on the rig ... all gave different results but none of them gave me the wave form on the screen | |
| | #8 |
Post a clear picture of the front panel with the control markings, if you can.
__________________ Carl Curmudgeon Elektroniker | |
| | #9 |
| It's possible that the function is selectable on the time base switch, but that switch is non-functional. That would explain why you didn't get the wave form.
| | #10 |
I'll post some pics with better quality tomorrow and try to see if I can find a switch for changing modes and see if its operational.
| | #11 |
I tried gurggling your scope model, but the only relavant result I got was our thread. HA!
| | #12 |
There were many oscilloscopes made as X-Y scopes: the Tektronix 600-series of monitors is a good example, normally sold as OEM to companies incorporating the scopes as display devices in various machines, such as medical diagnostic equipment. Unless you have an external sweep unit (rare units, such as the Tektronix RG501), you won't be able to inut a useful sweep to the device where you can trigger to have a stable waveform. Dean
| | #13 |
Sorry it took me so long to reply. I fixed it. One switch had a mode with the sign "/\/\/\" on it. On that mode, when there is no signal at the input I see a horizontal line not a dot. When I input a signal I can see its shape )I'll post some pics later so that you can see how big is the thing... and how old )Thanks to everyone who tried to help me. | |
| crt, oscilloscope |
| Input circuit needed for PC Oscilloscope! | princejim | Electronic Projects Design/Ideas/Reviews | 2 | 23rd April 2007 07:45 AM |
| >20V on PIC input? | William At MyBlueRoom | Micro Controllers | 5 | 31st July 2006 12:00 PM |
| Oscilloscope: How to use Z-Axis input? | Cifrocco | General Electronics Chat | 4 | 10th April 2005 10:39 PM |
| One of R/G/B input into RGB / SVGA monitor input | mrmacaulay | General Electronics Chat | 0 | 19th August 2003 06:38 PM |
| How to change 8 PIN mini DIN video input to RF input | helpmeplz | Electronic Projects Design/Ideas/Reviews | 0 | 5th December 2002 03:32 AM |
