I need a low battery warning circuit that turns on an LED when two 9V batteries need replacing.
If anyone has a circuit like this or knows any websites which cover this kind of stuff please help. I am limited for space so the smaller and simpler the better. Thanks John
The first rule of mstechca club is do not talk about mstechca club. http://www.electro-tech-online.com/s...induser&u=1245 |
Thanks again Nigel, it looks quite simple.
I am using two 9V cells which drive a motor at 15v, I want to provide a warning when the battery is beggining to die. I see yours provides a warning once a 9V cell gives 6.5V, that seems a little low to me. What voltage would you suggest to turn on the led as the battery is just starting to run out? I would rather warn people too early than too late. Also should I just wire the battery warning circuit to one cell or both? As the whole battery will be replaced at once. Thanks
It seems it would be possible to use a opamp and a bargraph led to make it a more precise battery indicator correct? Also, I was under the impression that nine volts batteries held 9 volts of voltage until the very end where there was a dramatic voltage drop. It would seem that the circuit there measures a drop in voltage.
The battery voltage gradually falls during use, and then drops more suddenly at the end (at least for Nicad or Alkaline) - it's somewhere along the gradual fall you have to detect. |
