+ Reply to Thread
Results 1 to 3 of 3
Thread: ne555 and 7555
  1. #1
    preetijoli Newbie
    Join Date
    Jun 2009
    Posts
    6
    ne555 and 7555
    whats the difference between ne555 and cmos version of 555.
    i m doin a project which requires 555 , i m using ne555, when the output of 555 goes high, it give 3.8 volt with 5V power supply. How can i get 5v high output by using 5V supply only? by using cmos version? is there any way in which output 3.8V can be converted to 5V without using another chip? how exactly?
  2. #2
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    11,827
    Look at the datasheets.
    The 7555 only uses a fraction of the current of the NE555.
    At low currents the output swing of the 7555 is nearly rail-to-rail.
    I can't remember what the 555's is, I think it's 0.7V negative to 1.4V positive, check the data sheet, I could be wrong.
    The NE555 can supply 200mA, the 7555 can only supply 100mA. Check the data sheet, I'm sure the saturation of the 7555 can exceed that of the 555 under certain conditions.
    if I know the answer.
  3. #3
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,292
    The output of a Cmos 555 (7555 or LMC555 or TLC555) can reach +5.0V with a +5.0V supply only when its load current is zero (an input of a FET or a Cmos IC).
    With a +5.0V supply the output high voltage with a 2mA load is a minimum of +4.4V for an LMC555.
    With a +5.0V supply the output high voltage with a 1mA load is a minimum of +4.1V for a TLC555.
    With a +5.0V supply the output high voltage with a 0.8mA load is a minimum of +4.0V for an ILM7555.
+ Reply to Thread
  1. Interesting 7555 circuit.
    By Hero999 in forum General Electronics Chat
    Latest: 21st July 2009, 12:49 AM
  2. 5 Questions on NE555
    By Suraj143 in forum General Electronics Chat
    Latest: 3rd April 2007, 05:57 PM
  3. LMC555 vs 7555...
    By captainkirksdog in forum General Electronics Chat
    Latest: 12th May 2005, 07:59 PM
  4. How do i use the NE555 Chip??
    By radialspel in forum General Electronics Chat
    Latest: 9th April 2004, 11:02 AM
  5. CMOS 7555 Calculator ?
    By DaleHall in forum General Electronics Chat
    Latest: 15th February 2004, 01:51 AM
Tags for this Thread
