Well as the title says, I am at the stage where I would like to have a crack at etching my own PCB. Could you take a look at the following list and tell me if I am missing something, some bits may seem a bit extravagant but I want to ensure that any problems are because of lack of experience and not having the "right tools". Processing Tray Ferric Chloride Etchant Tin Plating Crystals Etch Resist Pen Universal Solvent PCB Board Polifix Block Press-n-Peel Thermometer Gloves Safety Glasses What do you think? I was wondering about what might be the best container to store the Ferric Chloride and Crystals - any ideas? Many thanks Mark Last edited by UTMonkey; 19th June 2009 at 07:32 PM. | |
I would think that a special bottle used for photo-developing chemicals would be suitable for the ferric chloride. A glass container might work, if it is not photo-sensitive. Just a suggestion ... not experience related. | |
So what container do you use to store a "Universal Solvent"?
__________________ Carl Curmudgeon Elektroniker | |
| The liquid feric chloride from radio shack comes in a plastic bottle. Storing it in a metal bottle would be a bad move.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #5 | |
![]() I've stored my NaOH developer and ferric chloride solutions in translucent HDPE bottles for years, never had a problem. Jeff
__________________ Nothing is impossible for the man who doesn't have to do it himself - Weiler's Law | ||
| | #6 |
Thanks for your suggestions, what do you think of my shopping list?
| | #7 |
I use a quart size bottle from engine oil (had a leaky car, always laying around), rinsed it out very well. Just seemed like the most chemical resistant container on hand, and I want to etch... Cheap food containers work well for etching trays. Mostly use them to sort and store parts, but it was about the right size for the boards I etch, and had plenty on hand. I use toner transfer, a little touch up sometimes with a Sharpie marker. They come in an extra fine point now, bought a couple at Walmart when I saw them about a month ago, but haven't needed them yet. Should have written something on my last set of boards, just to see if the work as well. Thermometer? Seldom drops below 70 degrees here in Florida. Solvent, I use Acetone. Cheap, easy to find, and works for most things, even plastic repair... Still have half the can I bought 5 years ago, and use it for a lot of stuff besides electronics. | |
| | #8 |
You will need some drills to finish your PCB. You will have to be very good to make these holes just holding a dremel in your hands. A holder that convert it as a drill press is better. Before I was using my big drill press that spin at a maximum of 10 000 RPM. It was working pretty well. Never broke a bit. Now I use a small CNC machine that I assembled from parts found here and there and I drill my holes as the first step, before toner transfer and etching. Alain Last edited by AlainB; 20th June 2009 at 04:23 PM. | |
| | #9 |
what kinds of drill bits you recommend for drilling PCBs? recently i bought a titanium coated one...because the usual black drill bits don't last for more than 2-3 boards... if i don't brake them...they become less sharp and they don't drill as fast as they did... i have also ordered some cobalt ones... | |
| | #10 | |
A bottle (or 2) of cheap fast dry nail varnish, cheaper than the PCB pen and better/faster for large coverage like ground planes etc. Washes off in acetone and you can also use it for fixing tiny screws, trimpots etc. If using pressnpeel I really recommend spending $25 on a cheap laminator even if you have to mod it to turn the heat up a bit. | ||
| | #11 | |
Mine are comming from a local flea market. It is possible that they have been resharpened too. As far as the size, I use almost only the bit #63. It is the smallest that I have. I use that size for all the PCB holes and I use the reamers that you see in the picture if some holes are too small. #63 is very small but sometimes, not small enough. I think that the #68 would be better for IC's. Alain Last edited by AlainB; 20th June 2009 at 07:07 PM. | ||
| | #12 |
I would recommend using the Sharpie Industrial instead of the regular Sharpie. I say this because I used to plot boards using regular Sharpies in a flatbed plotter years ago and they worked great. Several recent attempts to use them gave me barely usable boards as the ink washed off (not completely) and the traces were nearly etched away. I can only guess that the ink has been reformulated. I now use the Industrial version with the same plotter and get great results. Jeff
| | #13 |
In my last attempt to created fine-pitch PBC, I had a problem while attempting to drill the pads. The process drilling tended to tear the pad away from the board, runing all my hard work. I though it might be better to drill before etching. Am I the only one who has that problem? | |
| | #14 | |
Unfortunately, they don't make the extra fine tip anymore. Last fall, I phone to the Company because I could not find it in Montreal and they confirmed that fact to me. It is discontinued! Too bad! But my informations are from last fall. Maybe they started to make them again! Who knows! Alain Last edited by AlainB; 20th June 2009 at 07:22 PM. | ||
| | #15 | ||
Also, how much copper is to be left around the finished hole? If the pad is only slightly larger than the drill, the copper can easily be torn off during drilling. Jeff
__________________ Nothing is impossible for the man who doesn't have to do it himself - Weiler's Law Last edited by jbeng; 20th June 2009 at 08:33 PM. Reason: added more words | |||
| brew, pcb, ready |
| Home brew SMPS | Thunderchild | Electronic Projects Design/Ideas/Reviews | 4 | 28th March 2009 11:25 AM |
| Building home-brew digital clock | littletransistor | General Electronics Chat | 19 | 2nd August 2008 05:03 PM |
| Home-brew solar cells | jake_stone2000 | General Electronics Chat | 10 | 10th June 2008 06:49 PM |
| Need help with home brew project | G_Man | Electronic Projects Design/Ideas/Reviews | 43 | 6th March 2008 09:24 PM |
| getting ready to make my PCB | jrz126 | General Electronics Chat | 9 | 17th October 2004 03:04 AM |
