Old 19th June 2009, 09:54 AM   #1
Post Relay switching compact fluorescent lamp
I use a 10A/277VAC to control 10 CFL with 40W each and found that the life span of the relay is reduced tremendously. The contact of the relay is welded. There is no problem to use the relay to control halogen eventhough up to 1000W. What is causing this and any method to protect the relay contact from welded?
chchuah is offline
Old 19th June 2009, 11:54 AM   #2
you could mount a capacitor across the contacts, and also use a smaller relay to disconnect that capacitor after 1/2 second or so.
can't really say what capacity, for 10 tubes, maybe a few uF.
also I am not expert for energy electronics, but that is what I believe would be a helping. So it is just what i would try.
nike6 is offline
Old 19th June 2009, 03:53 PM   #3
I think your problem comes from the turn-on surge, as the input capacitors on the CFLs charge up.
(I am surprised that it is worse than the tungsten lamp surges. They are quite bad as well)
If you fit a surge-guard NTC thermistor in series, the turn-on surge will be much less.
Diver300 is offline
compact, fluorescent, lamp, relay, switching
switching times of relay. alphadog General Electronics Chat 5 15th February 2009 03:49 AM
An light sensor and controls a relay activates street lamp analog circuit acting as a aceace Electronic Projects Design/Ideas/Reviews 2 2nd January 2008 02:54 AM
Compact fluorescent circuit davej General Electronics Chat 9 12th April 2007 09:26 PM
alarm help switching relay andrew2022 Electronic Projects Design/Ideas/Reviews 10 27th June 2006 10:00 PM
Switching relay with a pic? Jerran Micro Controllers 11 7th November 2003 05:05 AM
