+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 20 of 20
Thread: DIY Low Pass and Mid/High Pass (Bass Blocking) Filters
  1. #16
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,026
    The common (ground) connection for the batteries (minus side of the + battery supply and plus side for the - battery supply) and any other circuitry would be the common (coax shield, outer part of an RCA connector, or inner-most contact on a phone plug) of the audio connection.
    Carl
    Curmudgeon Elektroniker
  2. #17
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    Make the circuit on a printed circuit board, stripboard or perforated board. Connect everything that is shown grounded together. The input and output also have ground wires. The two batteries are connected in series and their junction is connected to ground.
    Or make the circuit with a single polarity supply as was shown.
  3. #18
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,026
    Quote Originally Posted by audioguru View Post
    The OPA2244 has even lower power supply current than the lousy old LM358 dual and LM324 quad low power opamps.
    But those old opamps have pretty bad crossover distortion so maybe the OPA opamps have even more crossover distortion?
    The LM358 and LM324 low power opamps have a very low max frequency at full output level.
    The OPA opamps also have a low max frequency (950Hz) at full output level which misses most of the range of audio frequencies.
    Those are some good concerns about frequency response and distortion.
    The slew rate is typically 0.1V/µS which gives a maximum frequency response of 16kHz at ±1Vpp, which should be adequate for most casual listening requirements. There isn't usually that much high frequency energy in music.
    There's no data in the data sheet about crossover distortion, so I can't answer that concern.
    Carl
  4. #19
    runslikealpaca Newbie
    Join Date
    Jun 2009
    Posts
    14
    what kind of op amp should i be using? is there a lower limit to the amount of voltage that can be used? or are all op amps the same and can run on any voltage?
  5. #20
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,026
    All op amps are different. There are differences in minimum and maximum voltage ratings, current used, frequency response, slew rate, and whether their inputs and outputs operate at the power supply rails (rail-to-rail). You have to look at the data sheets to determine their capabilities and limitations, and then determine the best for your particular requirements.
    Suggest you read a tutorial on op amps such as Operational amplifier - Wikipedia, the free encyclopedia to learn more about them.
    Carl
+ Reply to Thread
Page 2 of 2
First 1 2
  1. high pass circuit
    By chandra999777 in forum General Electronics Chat
    Latest: 13th December 2008, 09:34 PM
  2. Low pass filters & Notch Filter
    By maidmarion in forum General Electronics Chat
    Latest: 5th March 2008, 01:39 PM
  3. Band pass filters, from theory to practice
    By ikalogic in forum General Electronics Chat
    Latest: 13th January 2007, 07:04 AM
  4. controlling band-pass filters
    By aidanbre in forum Micro Controllers
    Latest: 15th April 2003, 07:32 AM
  5. band pass filters
    By aidanbre in forum Electronic Projects Design/Ideas/Reviews
    Latest: 29th November 2002, 06:43 AM
Tags for this Thread
