+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 25 of 25
Thread: How to reduce the voltage needed for a photointerrupter
  1. #16
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,772
    The sensor data sheet shows an internal resistor in series with the LED and op amp. It would be unclear where that resistor is, until we study the photograph carefully and compare it to the data sheet electrical and mechanical drawing.
    After some study, some of us decided that the unmarked resistor in the data sheet is the 3.3k resistor that's visible on the underside of the sensor assembly. I, (and apparently kchriste) felt that matching the current consumption into the V+ pin was the best way to choose the new resistor value.
    Since this resistor is internal to the sensor, choosing its value does require careful study of the sensor data sheet. I think that suggesting a change to the part without looking at the data sheet was hasty.
    If you had some other resistor in mind, (external to the sensor?), I was confused and please accept my apology. Actually I still am confused.
    de KI6RWX
  2. #17
    AlainB Okay
    Join Date
    Jan 2008
    Location
    Montreal, Canada
    Posts
    127
    This is another part that I have. Its number is S7275-1 and I did not found any datasheet for it.
    The circuit being more complex I just tried it without modification at 5 volts and to my surprise It is working. I then tried an unmodified one like the first one and it is working too at 5 volts. Same crisp and clean trigger.
    For the usage of this part, as I understand it now, the CNC software keep the photointerrupter dedicated parallel port pin high. Since its output (of the part) is floatting when not trigered, the port pin stay high. When triggered, It connect the ground to the port pin forcing a low witch indicate to the software to stop everything. Does it make sense?
    Alain
  3. #18
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,772
    I'm seeing four devices. Are they marked "303", "122", "221", and "PA" ?
    de KI6RWX
  4. #19
    AlainB Okay
    Join Date
    Jan 2008
    Location
    Montreal, Canada
    Posts
    127
    "303","122","122" and "PA"
    I suppose that because of the PA being there this part has a much higher output capacity then the other one??
    What is that PA? Is it a PNP transistor?
  5. #20
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,772
    PA is probably either a Toshiba 2SC4666A or 2SC3295A (which probably doesn't matter since I don't see any difference between them anyways). It would be a high gain (600-1200) NPN transistor, 150 mA, 50V. [edit] Actually it appears that it's probably the 2SC4666A because it's the narrower one.[/edit]
    Although the collector is rated at 150 mA, it's not wise not to push it because it could make the crisp operation much softer.
    de KI6RWX
  6. #21
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,674
    Quote Originally Posted by Mr RB View Post
    I had no way of knowing that without reading the datasheet which was not necessary or relevant to the good advice I gave re measuring the device and choosing a specific resistor value.
    Here I disagree, and that's all I have to say, about that, at this point
    If you think I'm worng then just say so, I'm wrong as often as the next guy. But don't explain what my words "mean" as if I was too stupid to choose the right words myself.
    I apologize for typing on your behalf or appearing to be condescending towards you. That was not my intent.
  7. #22
    Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent Mr RB Excellent
    Join Date
    Jul 2008
    Location
    Out there
    Posts
    1,757
    Quote Originally Posted by AlainB View Post
    Alain
    It's almost identical circuit to the other, again it si very typical of these devices. There are 2x 1.2k resistors in series (2.4k) to the power pin of the LED and photodiode (LED is on the right again) the photodiode forms a voltage divider to ground with the 30k resistor (303) and the centre of the voltage divider goes direct to the base of the output transistor which is NPN SOT-23 standard pinout BCE (top is B, bottom is E to gnd rail).
    The photodiode goes low resistance where there is NO obstruction to the beam, this causes the base of the NPN to go high and it has an open collector output. So the output pulls LOW when there is nothing blocking the beam.
    So now the big question... When you connect it to 5v power, what voltage are you getting on the LED and opto?
    To kchristie, sorry for jumping on you. It's just that it's a pet hate of mine when people explain what I "mean" especially when they don't get close to what I actually did mean.
  8. #23
    AlainB Okay
    Join Date
    Jan 2008
    Location
    Montreal, Canada
    Posts
    127
    Since there was different voltages present on the donnor machine, some parts working at 12 volts, some other at 24 volts and some other at other voltages and since the first device showed here is designed for 24 volts with a 3K3Ω resistor, could we deduce that this second one, with 2 - 1K2Ω resistors in serie is probably designed for 12 volts operation?
    If so then could we deduce that the resistor of the first device should be changed to something like 1K2Ω to work at 5 volts instead of the 330Ω mentioned previously ?
    Is this too simplistic?
    I am more concerned about the first device that can be easily modified. The second one, specially if it is effectively designed to work at 12 volts, I will keep it as it is.
  9. #24
    Join Date
    Jul 2008
    Location
    Out there
    Posts
    1,757
    They are both very similar, just that one has a 3.3k resistor and the other has a 2.4k resistor. Both use a sensitive NPN output transistor so the LED current is not real critical.
    If they work reliably with 5v supply then they work! Otherwise change the resistor to a lower value until it starts to work reliably.
    Also watch you don't get an sunlight or other ambient infrared into them, ie spotlights etc.
  10. #25
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,772
    If you want 'OEM' operation but on 5V, I would try to determine what the original supply current was (if you only know the voltage, set it and measure the current on the bench). Then change one or both of the 122 resistors until that current is achieved at 5V.
    This sensor is a little more versatile, too. If you have minor problems with stray light, you can reduce the 303 resistor (maybe as low as 4k7) to desensitize it.
    de KI6RWX
+ Reply to Thread
Page 2 of 2
First 1 2
  1. how to reduce voltage of a small solar cell
    By Mr.Eng13 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th May 2009, 12:44 AM
  2. how do I reduce the voltage in a circuit?
    By doitmyselfer0523 in forum General Electronics Chat
    Latest: 5th February 2008, 04:20 PM
  3. How to reduce voltage from a car battery ?
    By arunb in forum General Electronics Chat
    Latest: 20th December 2006, 05:49 PM
  4. voltage booster needed
    By kad in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th February 2006, 12:39 AM
  5. Reduce battery's voltage by half ?
    By mrmacgyver in forum General Electronics Chat
    Latest: 6th August 2004, 06:10 AM
Tags for this Thread
