+ Reply to Thread
Results 1 to 6 of 6
Thread: buffer ic
  1. #1
    antoine magdi Newbie
    Join Date
    Dec 2008
    Posts
    19
    Default buffer ic
    Hello everyone!
    It's my first time to use a buffer;
    can anyone explain in details what's the buffer (shift register or what), how i can enter my input to the buffer.... and then how to read it...
    if you want to take an example take the Rsb509b2 as an example!
    thanks in advance!
  2. #2
    Chippie Excellent Chippie Excellent Chippie Excellent Chippie Excellent Chippie Excellent
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    A buffer can be something as simple as a single transistor circuit used for impedance matching...a common base with the emitter as the input(collector as out) will match a low impedance source to a higher load...
    Eccentric millionaire financed by 'er indoors
  3. #3
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,788
    Quote Originally Posted by Chippie View Post
    Wrong sort of buffer!
  4. #4
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    Arggghhhh I missed the ic bit in the title........Should have gone to Specsavers... lol
  5. #5
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,009
    The Rsb509b2 is basically a FIFO (First In First Out) buffer. It has a memory (32 bytes in this case) which allows the input data rate and output data rate to be different (as long as the difference doesn't exceed 32 bytes). It allows for temporary storage of a momentary burst of input data at a rate higher than the receive circuit can accept.
    The IC has input and output clock and signal pins to allow the data to be read in and out at different rates. See the data sheet for details on how to do that.
    Carl
    Curmudgeon Elektroniker
  6. #6
    tariq7868 Okay
    Join Date
    Mar 2009
    Location
    Karachi, Pakistan
    Posts
    94
    buffers are basically used in any data transferring / receiving or storing devices.. any data that is received or that is to b sent is first hold in buffer then passed ahead when the other end device is ready,, to input data in the buffer parallel or serial clock is needed.. at a clock pulse the data (a word) is stored in the buffered..
+ Reply to Thread
  1. Buffer
    By hykwei in forum General Electronics Chat
    Latest: 7th July 2007, 01:08 AM
  2. buffer for the pic
    By Gaston in forum Micro Controllers
    Latest: 1st February 2007, 10:29 PM
  3. audio buffer
    By svtiss in forum General Electronics Chat
    Latest: 10th June 2006, 12:57 AM
  4. RS232 buffer
    By TDY in forum General Electronics Chat
    Latest: 18th March 2005, 08:36 PM
  5. buffer
    By cleopatra in forum General Electronics Chat
    Latest: 5th August 2003, 05:42 PM
Tags for this Thread
