+ Reply to Thread
Results 1 to 9 of 9
Thread: spike's energy level
  1. #1
    dark Newbie
    Join Date
    Nov 2008
    Posts
    198
    Default spike's energy level
    Can someone help me out with how the Joule rating for the spike is calculated say the following standard:
    EN60255 direct spike Level 5 KV waveform 1.2/50μs impedance 500Ohm .
    Then How much Joules this waveform has? I am little confused.
    Regards
    -Adi
  2. #2
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,025
    What does 1.2/50µs mean? What is the shape of the waveform?
    Carl
    Curmudgeon Elektroniker
  3. #3
    dark Newbie
    Join Date
    Nov 2008
    Posts
    198
    Quote Originally Posted by crutschow View Post
    I guess 1.2us rise time and 50us is 50% the fall value . EN60255 standard was asked me to in corporate I couldnt find much on the net
    Regards
  4. #4
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,025
    You would integrate the power over the waveform period to get the energy in joules. The following calculator should give you a ballpark number Welwyn - Calculation Tools.
    Carl
  5. #5
    dark Newbie
    Join Date
    Nov 2008
    Posts
    198
    You are simply great , thanks for the nice link . One help more regarding the calculator does it works for current waveform aswell ? . The drawing shows in terms of voltage.
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,025
    Quote Originally Posted by dark View Post
    To get power you need both voltage and current. If you have a current waveform then you need to know the circuit resistance to calculate the voltage and power.
    Carl
  7. #7
    dark Newbie
    Join Date
    Nov 2008
    Posts
    198
    The link you suggested accepts only peak voltage (no current) to determine the Joule?
  8. #8
    duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent
    Join Date
    Dec 2008
    Location
    nortern 'sconsin
    Posts
    1,822
    Crutschow is giving you good advice on how this problem is solved, not a magic bullet.
    That program also only works with square or exponential waveforms. A gaussian pulse is also common, but if you try to use a square wave or exponential as a model for, say, something approaching a Dirac delta impulse you could be off by a thousand to one.
    It also assumes you have a resistance, not a complex impedance - you said your load was an impedance. If you ignore the reactive effects of your load, again, you could be off by a ridiculous amount.
    Energy = Power x Time. You integrate (or more typically do a Riemann sum approximation) of the power waveform over time. Unless your problem fits that calculator exactly, you will get a much closer number by doing the Riemann sum approximation with pencil and paper by plotting a lousy half-dozen points. Or do it right and use a spreadsheet. First, you need to understand what it is you are doing.
    Power isn't simply voltage or current, it isn't simply force or distance. This is a very important concept that over-unity nutters are always getting wrong. Your voltage will have one function into a complex impedance, your current will have another. You need both.
  9. #9
    dark Newbie
    Join Date
    Nov 2008
    Posts
    198
    Quote Originally Posted by duffy View Post
    Duffy , I talk with regards to "EN60255 direct spike Level 5 KV waveform 1.2/50μs impedance 500Ohm " and not Dirac delta or square impulse . The standard description shows the voltage rising as an exponential function and rise time and fall time has been mentioned. Crutschow's suggested link is producing results rather on the higher side but arnt too off the path . What my concern is in the standard mentioned above the peak current looks like 10Amps is it correct to deduce like this.
    Thank you
+ Reply to Thread
  1. Types of Alt Energy/Future of Alt Energy
    By Johnny Ohm in forum Alternative Energy
    Latest: 14th September 2008, 01:48 PM
  2. Converting from guitar level to line level
    By joecool85 in forum General Electronics Chat
    Latest: 23rd March 2006, 01:04 PM
  3. Wind energy to electric energy
    By Vaibhav Birit in forum General Electronics Chat
    Latest: 28th July 2005, 01:58 PM
  4. energy or power
    By electronist in forum General Electronics Chat
    Latest: 9th October 2004, 06:18 PM
Tags for this Thread
