Old 31st May 2009, 02:55 AM   #1
Default Engine Not Running Alarm
I want to power a Sonalert if the ignition is turned on and engine hasn't been started within ~30 sec. Standard GMC V-8 with points-ignition, and an 14V alternator. Have access to both sides of the ignition key switch and a wire from the distributor points (already feeds tach). I need to turn on the ignition switch on my boat to raise or lower the outdrive, and I have left the ignition switch on.
I'm thinking about a delay timer whose timing period is reset by the distributor signal (so that it never times out if the engine is running) or a voltage detector & timer (to detect 14V from the alternator if the engine is turning) .
Anybody come up with something simpler?
MikeMl is offline
Old 31st May 2009, 03:21 AM   #2
You could just move the line to the lift and lower system to a separate switch independent of the ignition or move it over to the ACC side. Just a thought.
A simple 555 timer with a few additional components could easily be set up as a time delay device too. Just use the power that come back from the ignition coil to the tach to trigger a transistor that keeps pulling the 555 reset down/or up when the engine is running.
"Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
"Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
"Your impossibility may just be my day to day routine." -- tcmtech
tcmtech is online now
Old 31st May 2009, 04:24 AM   #3
Originally Posted by tcmtech View Post
You could just move the line to the lift and lower system to a separate switch independent of the ignition or move it over to the ACC side...
No accessory contact on the ignition key switch, just +12V, IGN and START (momentary). The lift has an indicator lamp which lights to tell you that the outdrive is not down and locked, so it it is wired through the ignition switch so that the lamp only comes on when engine is running, and doesn't stay on all night while beached.
The problem is that after putting the boat on the trailer, I sometimes have to turn on the ignition switch to raise the outdrive and that's when I have left the key on. Moving the power feed to its own circuit is problematic because if the engine is running, you want to know that the outdrive is not up before you go in gear, and if there was a separate switch it could be in the wrong position. Maybe some diodes to power the lift circuit either from its own switch OR from the IGN switch?
MikeMl is offline
alarm, engine, running
alarm circuit for alarm clock skinnie339 Electronic Projects Design/Ideas/Reviews 2 26th April 2009 01:41 PM
EM-401 GPS Engine cabala Electronic Projects Design/Ideas/Reviews 1 7th December 2008 06:52 PM
My Engine runs! jrz126 Chit-Chat 19 6th June 2008 07:46 AM
Display running engine vibrations. john1 Electronic Projects Design/Ideas/Reviews 18 18th April 2008 05:39 PM
Engine tachos req RK NAIR General Electronics Chat 1 11th December 2004 07:14 AM
