Old 30th May 2009, 10:02 AM   #1
Cool Help to stop burning compoents
I have just built a small tranistor radio, im about to mount it into a box but in the handling five wire have come off, il obviously have to resloder them but i have an issue, it has a small IC, the type that looks like a transistor but is different, and a few over semiconductors, the PCB is very small only about 1'' by 3'' and im worried that in reslodering im going to burn these components out, Im not sure wheater a heat sink clamp will be enough to stop it, I usually use a IC socket but seeing as this was transistor like I didnt bother, does anyone have any suggestions?
Thanks SlicRic
SlicRic is offline
Old 30th May 2009, 10:06 AM   #2
As long as you are careful when you solder and you do not normally burn the copper tracks on the board, the other components should not have enough time to heat up.
Apply heat gently and for a short amount of time when soldering the wires and you should be fine.
edeca is offline
Old 30th May 2009, 10:32 AM   #3
You have to exceedingly poor at soldering to damage any modern silicon components, it should only take a second or two at the most to solder a joint.
Old 30th May 2009, 12:02 PM   #4
That is true, however, this piece is very small, i will have to remove joints and then replace them, as i said in the original post i have never handled an IC like this, i do not no its specs
SlicRic is offline
Old 30th May 2009, 12:31 PM   #5
It should be fine, like I said you have to be amazingly bad to damage anything.
Old 30th May 2009, 01:05 PM   #6
Take a look at this page: EPE "Basic Soldering Guide"
The section on "desoldering methods" should help you. Desoldering braid is very useful and works very well.
edeca is offline
Old 30th May 2009, 01:25 PM   #7
I think you are talking about an SMD component. EPE January 2009 had a very nice article on SMD soldering and desoldering.If you have access to it then it would be very helpful.
Wond3rboy is offline
help!, ic's, stop burning
Bits are burning in my JA-S11 Amp mike11298 General Electronics Chat 5 24th December 2008 05:11 AM
Start-Stop & emergency stop Shohadawy Electronic Projects Design/Ideas/Reviews 2 28th September 2008 12:29 PM
Burning hex to PIC Rusttree Micro Controllers 17 1st July 2006 03:11 PM
Burning Magnets windozeuser General Electronics Chat 9 19th November 2005 08:00 PM
Too much current burning my amp? schrodingerscat Electronic Projects Design/Ideas/Reviews 6 13th September 2003 11:24 AM
