Hey, I am experimenting with CV measurements and I was wondering if anyone knew, or knew how to find out what the W/L is for the 2n7000. Do I have to call up FS to get this info? Will they tell me? | |
I hate acronyms I didn't even understand that post. What are CV W/L and FS?
CV - capacitance voltage W/L - width/length FS - fairchild semiconductor | |
It's the same as any TO92 transistor. What are you trying to build? | |
I'm actually an intern at a semiconductor place, and I'm tasked with using an expensive piece of test equipment to make CV curves to verify that our process is making the right oxide thickness/doping levels etc. To make sure I'm not getting bogus measurements I am using a known transistor so I can compare them to the datasheet, but the datasheet doesn't have everything. | |
| | #6 |
Try using a transistor that does have more in the data sheet. I'd give the NTE123A a shot. It's a generic replacement for old fav's like the 2N2222, 2N3904, 2N4401, and the 923C. I haven't looked at a DS for the 2N7000 in a while, so I can't say if the NTE123A will match your freq/gain/C-B-E voltage/current requirements or not. But I'd bet the data is a lot easier to find.<ckd>
__________________ <ckd> "Chance favors the prepared mind."--Louis Pasteur (1822 - 1895) -------------------------------------------------------- "There is only one good; knowledge, and one evil; ignorance." --Socrates 470B.C.?-399 B.C.? | |
| ratio, w or l |
| 2N7000 as PIC input | cn00728 | General Electronics Chat | 10 | 5th May 2009 08:25 PM |
| Possible to Replace 2N7000 with 2N2907/2N2222? | Krumlink | Electronic Projects Design/Ideas/Reviews | 17 | 28th March 2009 02:39 PM |
| Using a 2N7000 LED indicator, will it not load down an input? | blueroomelectronics | Electronic Projects Design/Ideas/Reviews | 21 | 10th February 2008 06:32 PM |
| pchannel version of 2N7000 ? | William At MyBlueRoom | General Electronics Chat | 3 | 27th May 2006 12:35 PM |
| 2N7000 does this work? (in a common anode display) | William At MyBlueRoom | General Electronics Chat | 16 | 24th April 2006 08:13 PM |
