Old 29th May 2009, 06:31 PM   #1
Default IR receiver
I posted this in an earlier post:
Remote Controlling Your PC
What does the 78L05 do? I assumed it was a normal transistor but it looks to be something else? Sorry to be such a newb...
GatorGnet is offline
Old 29th May 2009, 06:58 PM   #2
It's a 5V regulator.
Bill
Smart Kits build Smart People
Old 29th May 2009, 07:11 PM   #3
The only ones I found with the part number 78L05 are hard to find. I assume the normal 7805 will work?
Old 29th May 2009, 07:12 PM   #4
Yes. The L = 100mA rated.
Bill
Old 29th May 2009, 07:14 PM   #5
Try google first, the 7805 is WELL documented on the net.
straight answer, har har."
Sceadwian is online now
Old 29th May 2009, 09:45 PM   #6
This schematic uses the three pin IR module. What is the difference between them and the two pin IR detectors?
Old 29th May 2009, 09:51 PM   #7
You need the three pin, it's has a small IC demodulator inside.
Bill
Old 29th May 2009, 11:52 PM   #8
Well I got one built. After debugging some things I got it working. Now I have an issue with incoming data.
When I push a button on the remote I get random data coming in:
Outputting raw mode2 data.
space 1382017
pulse 9026
space 4443
pulse 571
space 4418
pulse 562
space 4430
pulse 566
space 2177
pulse 564
space 4427
pulse 568
space 4421
pulse 567
space 4425
pulse 565
space 2179
pulse 575
space 2170
pulse 567
space 2177
pulse 567
space 2179
pulse 569
space 2175
pulse 571
space 2172
pulse 576
space 2170
pulse 575
space 4414
pulse 576
space 2170
pulse 573
space 2170
pulse 571
space 28222
pulse 9052
space 2199
pulse 574
btw, this is from one button push.
When I push the same button again, I get different data coming in.
Could this be the remote or is it something with my board?
Old 30th May 2009, 12:27 AM   #9
What remote are you using? What's it set for?
Bill
Old 30th May 2009, 12:48 AM   #10
One is a Toshiba CT-852 and the other is for our comcast cable box. Both give random data when pushing one button. The software I am using states that the remote is using a special repeat code. I just wanted to make sure that my receiver I spent some good time building is working right.
Old 30th May 2009, 02:09 AM   #11
That is the raw data. You need different software to interpret it. Your hardware appears to be working correctly.
Pommie is online now
Old 30th May 2009, 03:28 AM   #12
Why would the electronic companies that make those want to use data that changes each time you send it?
Old 30th May 2009, 03:32 AM   #13
The difference in the data is just timing errors. The times are converted to 1 and 0s and come out as the same number each time. Looking at the data something near 4000 is a one and 2000 is a zero. The 500s in between are just gaps. Edit, and 9000 is the start pulse. See Atomsoft's thread on IR for example code.
receiver
Old GPS USB receiver to LCD dchurch24 General Electronics Chat 2 12th August 2008 10:00 AM
rws-375 receiver balkesli Electronic Projects Design/Ideas/Reviews 1 30th June 2008 12:20 PM
AM receiver convert to ATC receiver Shelton General Electronics Chat 6 18th April 2008 02:37 AM
FM Receiver nye General Electronics Chat 10 19th August 2006 01:04 AM
GPS Receiver bonxer Micro Controllers 3 18th November 2004 06:32 PM
