+ Reply to Thread
Page 4 of 4
First 1 2 3 4
Results 46 to 50 of 50
Thread: Sensing current through AC motor
  1. #46
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,457
    You can't wait for a ready-to-use solution served on a silver platter.
    Do some small scale experiments using any toroidal core with reasonably thick wire (e.g. as used in dimmers), put some windings of wire around the existing coil and use different known loads (e.g. sandwich toaster or water boiler) to connect to mains.
    Then measure the output voltage at the secondary winding. If you deem it too low add some more windings.
    The toroidal will behave like any transformer being connected with the load in series with the only difference, that the voltage drop across it is pretty low.
    The photo I posted is part of practical experience and I explained it well.
  2. #47
    premkumar9 Good premkumar9 Good
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    I think what happens sometimes is that some people starts answering questions on which they don't have enough knowledge. It is OK.Nobody knows everything. But the problem is they don't show the humility to accept their mistakes and gets irritated when their replies are questioned. I am not intending any individual. Just mentioned one problem with many individuals.
  3. #48
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,457
    That shoe won't fit me.
    The toroidal as mentioned has been tested and is used in a functioning circuit.
    On the other hand, if you want 100% proof and a scientific dissertation about the problem then why not ask a university professor?
  4. #49
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    Quote Originally Posted by Boncuk View Post
    I don't know who are all in this forum. There may be professors also. Normally I post questions for practical applications. Not for any school assignment. The toroidal transformer you made may be working fine for your application. My requirement is different. So I need to know the design aspects also to make one suitable for me. Doing it on trial and error basis may not be practical for me. I am thankful to you for all your suggestions. But my only suggestion not to get irritated when somebody questions your statements.
  5. #50
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,457
    Quote Originally Posted by premkumar9 View Post
    Still unsatisfactory, because the answer doesn't include an exact describtion about the object to use.
    With other words, you expect a ready-to-go design as well as you expect to do the trial and error work for you by others. (Served on a silver platter)
    There is absolutely nothing to question if a tested and working design has been described.
    So get your butts up and do some research for your special requirements. The start is given.
+ Reply to Thread
Page 4 of 4
First 1 2 3 4
  1. AC Current Sensing without using a current shunt
    By jbarnaby2000 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th May 2009, 12:24 AM
  2. current sensing in AC
    By rjvh in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th June 2008, 03:32 PM
  3. PIC for sensing motor current?
    By Hank Fletcher in forum Micro Controllers
    Latest: 4th October 2007, 11:45 PM
  4. motor current sensing
    By eddanae in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th June 2006, 06:07 AM
  5. Motor current sensing
    By ptewright in forum Electronic Projects Design/Ideas/Reviews
    Latest: 19th May 2006, 12:29 AM
Tags for this Thread
