Old 26th May 2009, 06:11 PM   #16
Thanks everyone for their replies. It is much appreciated.
gabeNC is online now
Old 26th May 2009, 06:14 PM   #17
Oh I know eric, I just wanted to make sure he was actually putting them in, not just thinking the big electrolytic on the 555 alone was going to solve the problem. Sorry if I seemed like I was trying to butt heads =)
straight answer, har har."
Sceadwian is offline
Old 26th May 2009, 06:19 PM   #18
It would be good if gabe lets us know how it goes.
ericgibbs is offline
Old 26th May 2009, 06:24 PM   #19
I've got a large 200volt 2800uf cap from an old UPS... would that keep the LED's from dimming?
I'm kidding
I'll let you guys know how it goes.
Old 26th May 2009, 06:36 PM   #20
Hey seriously if it fits throw it on <smirk> Just watch out for the brownout from the intial charging current =) Every time I plug an ATX supply in the lights in my house dim, biiiiig primary buffer caps.
Old 27th May 2009, 05:19 AM   #21
You could put a 1/2 second startup delay in the PIC code, it's generally a good idea for a lot of circuits. That way if something causes a PIC reset you will see a very obvious 1/2 second pause.
Mr RB is offline
Old 29th May 2009, 10:43 PM   #22
Alrighty gents I finally got around to slapping some big caps on this circuit because I'm hooking it up to my 3 phase mains in my barn and right now i'm about to flip the swit%+@$%&
[NO CARRIER]
Old 30th May 2009, 03:16 PM   #23
added a 470 to the input side of the 7805, a 10 to the output side a couple of 10uf tantalum caps to the PIC and a 470 close to the 555 timer.
changed the code in the pic to flash the decimal point twice before the loop (which counts from 0-9) and everything is working well, no random restarts and the seven seg is quite a bit brighter than before. I wonder if is also has to do with the different PIC on the breadboard. Went from a 876a to a 877. I can't program the first one anymore, might have fried something. With no decoupling caps, guess i'm not surprised.
thanks for all the help gents!
Old 30th May 2009, 06:12 PM   #24
Why are you using a 555 as well as a PIC?
Can't you program the PIC to flash some LEDs as well?
if I know the answer.
Hero999 is offline
Old 31st May 2009, 01:04 AM   #25
yup... you're right. I was playing with a 555 at some point and just left it on the breadboard. Just messin' around. But having it on there, did help me to learn something practical with decoupling caps.
555, causing, pic, reset, timer
555 timer reset mlt57sooner General Electronics Chat 2 22nd April 2005 04:26 PM
LCD backlight causing problems MrMikey83 Micro Controllers 6 6th February 2005 11:12 PM
JDM ICSP programming ok, but causing reset of circuit anthonybradley Micro Controllers 2 4th January 2005 12:31 PM
Power-On Reset & Brown-Out Reset hantto Micro Controllers 5 31st August 2004 12:14 PM
555 timer circuit reset function Uman Electronic Projects Design/Ideas/Reviews 1 24th May 2004 05:38 AM
