Hi, I wanted to know how does RTD (Resistance Temptature Detector) works? and how Thermocouple works? and what is the difference between these two temp sensors? Thanks, Ohad. | |
THermocouple- very high temperatures possible, relative temperature measurement only between two points, cheaper, more durable RTD- more expensive, absolute temperature measurement, the most stable, the most accurate, linear (if you use the right material of course)
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 27th May 2009 at 01:21 AM. | |
__________________ Don’t argue with idiots.......they will drag you down to their level and then beat you with experience! | |
Thermocouple utilizes Seebeck effect that says the dissimilar metals will product a small voltage proportional to temperature. A RTD is a wound resistance wire (usually platinum) that changes resistance with temperature. Lefty
__________________ Measurement changes behavior Last edited by Leftyretro; 27th May 2009 at 04:41 AM. | |
| | #6 |
Hi Leftyretro, yes i read about seeback effect, but i don't understand what happens to the metals when the temp is going up or down. i mean to the current carriers (or electrical energy), are their number changed due to changes in temp? and that is the reason for voltage that is created between the two junctions? Thanks for your help. | |
| | #7 | |
| | #8 | |
Thermoelectric effect - Wikipedia, the free encyclopedia http://www.omega.com/temperature/Z/pdf/z021-032.pdf
__________________ Measurement changes behavior Last edited by Leftyretro; 28th May 2009 at 01:49 AM. | ||
| | #9 |
Hi All, What does it mean when is written on electical device's specification the following: Isolation Voltage: 3000V Thanks. Ohad. | |
| | #10 |
Thanks[ QUOTE=Leftyretro;745039]You would have to research for the physics involved, much more in depth then can be put here. Lots on the Internet: Thermoelectric effect - Wikipedia, the free encyclopedia http://www.omega.com/temperature/Z/pdf/z021-032.pdf[/QUOTE] | |
| rtd, thermocouple |
| Using thermocouple with PLC | husnain | Electronic Projects Design/Ideas/Reviews | 4 | 7th January 2009 07:43 AM |
| K Type Thermocouple | yngndrw | General Electronics Chat | 9 | 14th March 2008 02:39 AM |
| thermocouple project -- help, please | Matt Bower | Electronic Projects Design/Ideas/Reviews | 8 | 21st June 2007 09:40 PM |
| Help - Amplifier for Thermocouple | AFMatos | Electronic Projects Design/Ideas/Reviews | 5 | 22nd February 2007 05:19 PM |
| Thermocouple generators | Thunderchild | General Electronics Chat | 31 | 12th October 2005 08:34 PM |
