| | #16 | |
Simply look at the datasheet of a modern transistor like a 2N3904: 1) With a collector to emitter voltage of 1V or more and a collector current of 10mA its minimum base current is one 100th. 2) With the transistor saturated with a collector to emitter voltage of 0.2V or less and a collector current of 10mA its minimum base current is one 10th.
| | #17 |
Why calculate it out? There's a traditional rule that the base current should be 10 times the collector emitter current to act as a switch, special cases aside, go by that general rule and you'll skip about 2 years of math.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 26th May 2009 at 07:21 PM. | |
| | #18 |
Some transistors like the BC547 have their saturation voltage loss rated when the base current is 1/20th of the collector current.
| | #19 |
It's very nice when it's specifically stated like that. Let you relax design requirements with assurance. I'm not an expert mind you, but everywhere I have read 1/10th is the rule of thumb, basically what you have to do is under all thermal and voltage conditions guarantee that the transistor will never come out of saturation and go into it's linear region or you'll get thermal runaway and transistor self destruction. I've heard little of safe operating area conditions but don't know much about them or how they're calculated.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 26th May 2009 at 08:03 PM. | |
| | #20 | |
There is no separate section on Fairchild's Data Sheet which differentiates between using the 2N3904 as an amplifier or as a switch, only how low can you get Vce! The test circuit where Ib=1ma is only to determine minimum switching speed, which is of no consequence to the OP who is switching an LED. At Ic=13mA, there is no requirement that the saturation voltage of the transistor be at an absolute minimum. A base current twice that determined by βmin is more than good enough... Last edited by MikeMl; 26th May 2009 at 08:28 PM. | ||
| | #21 | |
![]() Generally it's a question of stuffing as much current as you can down the base!. | ||
| | #22 |
hrmm mmrmmrm m fff mmhrr mfmmffr!
| | #23 | |
It is work in real (not in simulation).In your simulation it is turned-on when input voltage only 2V. When input reach 12V it is reach somewhat ~2V hard saturation. My value is ~1volt Vbe normal saturation (enough for driving the LED). This also my value for 5V input: 2K2//100pf Rb+C and 680 Rbe for fast ; 4K7 Rb and 1K Rbe for slow speed. Try it with simulation then, might be wont work, but it is work in real. ![]() | ||
| | #24 |
Also don't forget to look manufacture graphs about saturation characteristics (might be included in other transistor spec that specially for switch). Normally they used β=10 for saturation value. Last edited by Blatman Bond; 29th May 2009 at 10:33 AM. | |
| | #25 | |
your transistor will switch without any problems, relays will switch high voltages (125ac and above), the maximum voltage a transistor can switch is in its datasheet, also the maximum wattage, what you need to be concerned is that the current at the base of the transistor is small, how small? everything it's state in the datasheet | ||
| | #26 |
A 2N3904 transistor is an NPN type. When its emitter is at 0V then its base can never be higher than about 1.0V because the base-emitter is like a diode. The MCU applies up to 1V at a low current to the base to turn on the transistor. A 2N3906 transistor is a PNP type. When its emitter is at +12V then its base can never be less than 11.0V. Because the base is at a voltage that is much higher than the 5V for an MCU then a special circuit is needed in between. The collector's load voltage might go to the base of a transistor only when its load and the transistor blow up.
| question, transistor |
| transistor and transistor array question? | jokira247 | Electronic Projects Design/Ideas/Reviews | 9 | 25th April 2009 03:25 PM |
| Transistor question | Electronman | General Electronics Chat | 8 | 4th March 2009 11:40 PM |
| Transistor question. | Rumieus | General Electronics Chat | 14 | 4th September 2008 04:21 AM |
| Transistor Question | ScuzZ | General Electronics Chat | 3 | 6th January 2007 02:15 PM |
| transistor question | defcon31 | General Electronics Chat | 7 | 2nd January 2004 05:53 AM |
