Old 25th May 2009, 04:20 PM   #1
Default Resetting a Modulo 5 Down Counter
Hey I want to design a mod 5 down counter with a negative edge triggered jk bistables
All the examples I have seen have shown an up counter with the reset applied when the max number (and its equiv binary value) is acheived - then the count returns to 0.
In a down counter, Im not sure how to reset so that when it gets to value 0like so 5,4,3,2,1,0 - it resets back to 5,4,3,2,1,0 etc
I guess what i trying to say is how do i apply a reset to my 3 negative edge triggered j-k flip flops so that it goes from 5 down to 0 and then back to 5?
Its not homework but i think it will come up in my exam tmoro!
Can anyone help?
Callo1234 is offline
Old 25th May 2009, 04:45 PM   #2
It's not that much different for a ripple down counter. You're going to use a 3-input NAND gate on the three Q outputs. When all three outputs go HIGH, the count has rolled from zero to 111 and the output of the NAND will go LOW. You tie the output of the NAND gate to the PRESET input of the least-significant and most-significant F/Fs and the CLEAR input of the middle F/F. This will force the count to 101 (decimal 5) when it tries to "undercount" to 111.
You're lucky it's a ripple counter. Modifying the count of a synchronous counter and keeping it synchronous is a bit more complicated.
By the way, there are six states in your count sequence making it a modulo-6 counter, not a modulo-5 counter. It's the number of states in the count, not the maximum count, that determines the mod/modulo/divide-by number. That would be a good test question, too.
Dean
R.I.P.
Dean Huster is offline
Old 25th May 2009, 05:18 PM   #3
Dean
Thanks a lot, I understand so much clearer than the textbooks I bought. One thing, im pretty sure about but should check, in count down I have to take the clock signal for following stages from Qinverse? So each clock signal should be fed from the Q inverse of the previous FF, but I still feed the 3 Q outputs (not inverse) to the NAND gate for my reset condition.
counter, modulo, resetting
Help with power resetting problem vandyo Electronic Projects Design/Ideas/Reviews 14 18th January 2009 06:21 PM
Modulo 5 to Modulo 6 up-down Counter magik5 Electronic Projects Design/Ideas/Reviews 1 2nd October 2008 06:59 PM
Resetting Timer1 in a PIC richacm Micro Controllers 11 14th July 2008 12:37 PM
Resetting a clock back to 1:00 after 12:00 FastEddie Electronic Projects Design/Ideas/Reviews 10 10th October 2006 06:44 PM
PIC 16F873 resetting by itself? nclark Micro Controllers 10 30th June 2004 10:30 PM
