Old 30th March 2003, 04:12 PM   (permalink)
just a simple question, is it a buzzer of a speaker?
if it is a speaker with low resistance i dont think that you can hear anything
bogdanfirst is offline
Old 30th March 2003, 05:03 PM   (permalink)
Why Bogdan? :roll: Why will it not sound with speaker?
If the oscillator frequency is set within speakers range then the speaker should work. Also transistors used are capable of driving low impedance load.
kinjalgp is offline
Old 31st March 2003, 07:11 PM   (permalink)
look at R6=680R.....wich is in series with the "speaker".....
Old 31st March 2003, 07:55 PM   (permalink)
Well, bad news (for me at least :cry.
I tried putting a resistor in each transitor's base but the base-emitter voltage is the same :?: and got burned again. I tried changing transitors with bd1xx with dissipators and R4, R5 values. They didnt get burned but the speaker (it's a speaker, not a buzzer) didnt work. If i hold R4, R5 values, the same result. Reducing power supplies didnt work too.
Someone have said to me the problem maybe on capacitors, really? Which is exactly their function?
and what happens with R6, bogdanfirst? should I suppress it?
gothmog_es is offline
Old 31st March 2003, 09:18 PM   (permalink)
While enjoying the topic, I regret that I don't get it. Apparently the circuit is intended to make a sound when there is a short circuit. OK. A battery and a buzzer, right? On the other hand, this circuit seems to drive a pair of transistors when IC-A turns on. OK. But, when the IC is on, what have you got? The transistors do not make a multivibrator in this configuration. Even if they did, there is no driver/amp stage for the speaker. Seems like the most you could hope for would be a "click."
I do hope you get your project operational. If you remove the two troublesome transistors and short the circuit test leads, do you get a voltage at the IC-A output where there was none before? If you do, then that could be used to drive a sound generator (two transistors in an astable multivibrator - easy) BTW, did you design the circuit or did you find it in a book somewhere?
Gene is offline
Old 1st April 2003, 07:36 AM   (permalink)
I found the circuit at a site web (i wont do it never again): megatronica.cjb.net (in spanish).
In your message, i got lost at any time :? Till i know, transistors amplify stream from IC1A, which is connected like astable multivibrator. If the ends are opened circuit, signal at exits IC1b & IC1Awill be the same, so the speaker wont sound. If the ends are shorted circuit, signal at exits will be different and the oscillations of IC1A should arrive at the speaker, taking place the sound.
Old 1st April 2003, 03:50 PM   (permalink)
ok also if you were to short the leads you cant get a continous indication because you have the capacitor, c2....immm
Old 1st April 2003, 09:40 PM   (permalink)
I know you said...
Originally Posted by gothmog_es
bogdanfirst, i cant change the circuit now, because is for a project. Anyway, thanks for your help
and that's too bad. The circuit is a pile of confusing nonsense - at least to me. For the time spent trying to make it into a working short-circuit tester, you could have built 5 that actually worked from some of the circuits that have been recommended on this thread. If you do decide to start over with a new circuit, perhaps your instructor will be understanding. I would bet that every member of this group has tried to build published circuits in the past that just did not work - I know I have. Good luck in which ever path you decide to follow.
Gene is offline
Old 2nd April 2003, 09:29 AM   (permalink)
yes thats what i can say too...lots of circuits are not checked and there is lots of confusing stuff ok the 'net. you should check it with a sim program or something
Old 2nd April 2003, 07:37 PM   (permalink)
Default Continuity Tester
Maybe I'm a bit late joining in (sorry) but ...
I reckon the astable around IC1A and the transistor driver stage is OK,
What worries me is this +/- 12v oscillator is expected to drive into R4 and R5 (101 Ohms with leads open circuit - ONE OHM with them shorted :shock: ) No wonder they fry :!:
How true that the 'net catches as much as it helps :cry:
If we can rescue this with a bit of redesign ... :?:
Gothmog (if you are still here) what resistance do you want the circuit to sound at ?
Do you want to detect only absolute short circuits or should it sound for a few Ohms?
If the circuit is altered a bit it could work - your tutor should allow for this as almost every design I have seen 'evolves' rather than being perfect from the start ...
I need a memory upgrade ...
My head is full !
mechie is offline
Old 3rd April 2003, 12:34 AM   (permalink)
What worries me is this +/- 12v oscillator is expected to drive into R4 and R5 (101 Ohms with leads open circuit - ONE OHM with them shorted ) No wonder they fry
Well, i changed R4 & R5 values but i didnt get good results.
i think the speaker should sound with resistor's value around miliohms but precission isnt very important at this time.
thanks
Old 3rd April 2003, 12:41 AM   (permalink)
i thought it for a while simulate it on pspice but i havent ic**'s or transistor's models :cry:
anyway thank you very much for helping to me
Old 4th April 2003, 01:28 PM   (permalink)
Default Circuit Tester
Just finished scribbling this ...
I have NOT tested it, it uses the same oscillator as your design (IC1a, C1, R1, R2). The feedback is taken from the IC's output rather than the transistors so I can control the transistor stage's output (volume).
Component numbering containing a lower case 'a' denotes a new component (Ra2 for example).
A totally new input stage is created around IC1b.
Ra2 provides a bias into the test probe pair. If the probes are open circuit there will be a higher voltage on IC1b inverting input than that on the non-inverting. Ra3, Ra4, Da1 and Da2 provide protection to the op-amp input, Ca3 smooths the input.
If the probes are shorted together the output of IC1b will go positive. The diode Da3 will be reverse biassed and the oscillator, IC1a, will start. If the probes are open-circuited IC1b will go low and forward-bias Da3 which will 'clamp' the oscillator and stop it.
Any use to you ?
My head is full !
mechie is offline
Old 4th April 2003, 02:05 PM   (permalink)
mechie - How considerate of you to provide another circuit. Hopefully, yours will do the trick and goth will use it to complete his project. For some unknown reason, all previous attempts to convince him to alter his circuit have fallen on deaf ears.
Gene is offline
Old 6th April 2003, 10:25 AM   (permalink)
mechie, thanks for your work, i will answer for changing the project but i think is too different
by the way, which component is VR1? i dont recognize that symbol.
