Hi, Please could some one look at the attached schematic, and tell me what the symbol in yellow means ?. Thank you. | |
It's simple an output socket, looks like it may signify a screened one?.
That means an output socket, with the sheild connected to ground. Something like a phono socket or similar. Oh, Nigel got there first. Last edited by House0Fwax; 25th May 2009 at 11:38 AM. | |
It does not suggest screening. It's just a phono socket. Or it can be a BNC socket.
| | #5 | |
A BNC connector is a SCREENED connector.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| | #6 |
Wow !!! Posted,and replied in minutes. I have loads of downloaded symbols pages from the web,and the symbol wasn't on any of them. I come across this symbol problem from time to time, (I am electronics beginner). Thank you so much. | |
| | #7 |
| As is a phono socket.
| | #8 |
| Of course. ![]() I usually draw a 'screened' type connector symbol with a full circle.
| | #9 |
| | #10 |
| The metal case of the BNC is screening the mating connection, if the pcb mounted female part is grounded, which it should be. So its a 50Ω or 75Ω screened connector when in use, screened cable or not.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 25th May 2009 at 01:34 PM. | |
| | #11 |
| As with every single screened connector that's made - if you fit non-screened cable then it's obviously pretty pointless having a screened connector in the first place. But as far as BNC goes, unless you use exactly the correct screened cable, it's EXTREMELY difficult to fit a BNC connector. | |
| | #12 |
Can I add one more description to this pi**ing contest? It could represent a co-axial connector. I use the word co-axial to represent an RF type cable rather than just a screened cable, which may be fine at audio frequencies but have excessive loss at RF. As the circuit shown by the OP appears to be an amplifier for a low (RF) frequency loop antenna, I will stick with my description of co-ax connector as the output is intended to go to the input of a receiver which I guess will have a co-ax socket. JimB
| | #13 |
Wow, I've seen some interesting arguments here (I know I've started some of em ) but this one takes the cake.
| | #14 | |
| | #15 | |
As the pack had suggested a variety of specific socket types, just for the fun of it I thought I would try and drag it back into a more generic area. Incidentally, he phono plug/socket is considered to be quite a good socket for RF use, I have seen it used for making connections between modules at 160Mhz (ish) inside commercial radio equipment. JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||
| symbol |
| what symbol is this..? | nitE | General Electronics Chat | 11 | 4th March 2009 11:45 AM |
| Symbol ? | ATSRND | General Electronics Chat | 1 | 9th January 2008 04:05 AM |
| Mystery symbol | Roff | General Electronics Chat | 31 | 24th June 2007 03:03 PM |
| I can't believe I'm asking this, but the symbol for power? | Fusione | General Electronics Chat | 10 | 20th December 2006 02:11 PM |
| What does this symbol mean? | DJ_ReL@X! | General Electronics Chat | 6 | 24th October 2004 01:01 AM |
