Old 23rd May 2009, 10:41 PM   #1
Default preloading a power source
I have a 12v power supply I would like to preload the power supply with a 4amp draw befor starting the actual load
will adding a 3ohm 50watt resistor in parallel with the load do the trick or should I use something different
wjyates is offline
Old 23rd May 2009, 11:24 PM   #2
You'll be wasting 50 watts of power as pure heat, and you'll need to use more than a 50watt resistor unless you have a large heatsink attached to it. Why do you need to load it with 4 amps? And are you going to put a switch in to disable this once the load is connected? A few more details about what you're really doing would be helpfull (that is said so much around here it's not even funny)
straight answer, har har."
Sceadwian is online now
Old 23rd May 2009, 11:48 PM   #3
yes there will be a switch, transistor most likely with some sort of currant sensing device. hopfuly when the load is applyed, say 2 amps the currant sensing device will partly close the transistor reducing the resistance to 2 amps threrfor the power supply will never see the change
as to why ? just to see if I can. plus it may become part of anouther project
wjyates is offline
Old 24th May 2009, 12:21 AM   #4
Just because is a pretty poor reason to do something, all your effectively doing is keeping the power supply loaded and generating a bunch of heat, what good will that do you? Keep in mind the transistor when it's partially closed will be dissipating a bit of power itself, If you just buy a beafy power mosfet you can skip the resistor completly.
Old 24th May 2009, 01:22 AM   #5
I have a car alternator and I'm turning it with a motor from a cordless drill. using a seperate power suorce to get it started. ounce removed I can keep it running. but try to add another load it crashes.
I have another post"problem reading diagram" please read let me know what you think
thanks
now I have to learn how mosfets work
no, really.......... thanks for your imput
wjyates is offline
Old 24th May 2009, 01:52 AM   #6
Why can't you just connect the load to the alternator before you start the alternator with a cordless drill?
dknguyen is offline
Old 24th May 2009, 02:09 AM   #7
I could do that and it would probly work. but I would like to be able to turn different objects on and off. off is easy enough it's turning them on again thats the hard part. so the problem is to be able to get the motor to compensate for the load on the alternator with adding more load to the alternater. does that make any sence.
wjyates is offline
Old 24th May 2009, 06:45 AM   #8
Oh, I see. YOu have multiple devices being powered from the alternator and you want to be able to turn them on and off freely without having to restart the alternator because for some reason it shuts down when the load gets too low.
50W...that's kind of a huge resistor just to burn off power, or you'd need circuitry to monitor the output current of the alternator (everything except the resistor) and switch the resistor in whenever that current gets too low.
Any idea why the alternator shuts off when the load gets too low? Why would it stop? It's fuel powered...it's the fuel that keeps it spinning not the load.
dknguyen is offline
Old 24th May 2009, 09:52 AM   #9
Originally Posted by wjyates View Post
I have a car alternator and I'm turning it with a motor from a cordless drill. using a seperate power suorce to get it started. ounce removed I can keep it running. but try to add another load it crashes...
Sounds like you are exciting the field of the alternator off its own output. Probably one of the old crummy Motorola-style alternators that had the extra diode-trio.
If you use a battery or other DC source to feed the field terminal, the alternator will always produce output. It only takes a volt or so at about 80mA to bootstrap an alternator. Write back if you dont know what bootstrap means.
A standard automotive alternator will produce about 50A at 14V, or 700W. Since there are 746W per horsepower (HP), it takes a 1HP electric motor to turn a fully-loaded alternator. Your cordless drill motor is likely no more than 1/10 HP.
Why dont you post a diagram of how you have the alternator connected...
MikeMl is offline
Old 24th May 2009, 09:12 PM   #10
It's not the fuel that keeps it going,it's not even in my car, it's on my bench.
using 18v electric motor to turn altrenator,once up to speed the altrenators output is 27.5v. using ajustable voltage regulator cuts 27.5v down to 18 more or less witch powers electric motor,witch powers altrenator,witch powers electric motor. at this point I can diconnect power supply and it will run untill something breaks or I turn it off
wjyates is offline
Old 24th May 2009, 09:36 PM   #11
Sounds like you're trying to build an overunity generator.
Bill
Smart Kits build Smart People
Old 24th May 2009, 09:40 PM   #12
Yeah. Well then, of course it's going to turn off. You got no more energy entering in the system, and nothing is 100% efficient. So every time the energy cycles through the system you lose a bit.
And if you connect a load, it's definately going to turn off whehter it's 100% efficient or not, since now you are sucking energy out of the system with no more new energy coming in.
dknguyen is offline
Old 25th May 2009, 02:01 AM   #13
Don't they teach conservation of energy in high school science class anymore? Why do people still build these kinds of devices?
Old 25th May 2009, 03:40 AM   #14
I've got a little 12v light bulb inside a cube box made totally from miniature solar cells. There's nowhere for the light to leak out. It's been keeping itself lit up for years!!!
You just cant see it.
Mr RB is online now
Old 25th May 2009, 03:58 AM   #15
If you open the box does is there a dead cat or a live cat?
power, preloading, source
Isolated Power source amitak Electronic Projects Design/Ideas/Reviews 8 13th May 2009 08:30 AM
0-10V adjustable power from 12V source alexchannell General Electronics Chat 17 26th January 2009 11:56 PM
80W power source diablo1 General Electronics Chat 27 5th December 2008 08:28 PM
help with solar power source diddy5584 Alternative Energy 4 28th October 2007 03:51 AM
AC Power source Sarac Electronic Projects Design/Ideas/Reviews 12 18th July 2003 06:26 PM
