Old 22nd May 2009, 09:23 PM   #1
Default PWM from pic to analog voltage
Hi i need to design a variable output voltage with high efficiency. i need maximum 100ma at 12V. I was planning to use the pwm signal from A pic to control the voltage, can i do that with just a mosfet, inductor and capacitor? and maybe a flybak diode?
carmusic is offline
Old 22nd May 2009, 09:28 PM   #2
Yes, it's how the Junebug kit I sell generates VPP
http://en.wikipedia.org/wiki/Boost_converter
Bill
Smart Kits build Smart People
Old 22nd May 2009, 09:44 PM   #3
Thanx i will probably use buck topology,
carmusic is offline
Old 22nd May 2009, 09:59 PM   #4
What's your source voltage?
Bill
Old 22nd May 2009, 10:00 PM   #5
about 12V, my pwm signal is 5 V, i must be able to vary from about 3 to 12volt output at 100ma max
carmusic is offline
Old 22nd May 2009, 10:03 PM   #6
Does it matter if the polarity is inverted?
if I know the answer.
Hero999 is offline
Old 25th May 2009, 04:35 PM   #7
yes i cannot invert polarity since i use a common ground for other measurement. I will use a P channel mosfet switch, can you help me choosing right inductor and capacitor?. I was thinking using about 10uH and 0.47uf. i dont care if there is 500mv ripple. with higher caps, i have trouble getting low voltage output with low charge (my pwm cannnot go under 1% duty).
carmusic is offline
analog, pic, pwm, voltage
PWM to analog output: R/C radio to control analog joystick functions - any ideas? forrestking General Electronics Chat 21 11th May 2009 10:11 AM
0-24 V Analog voltage conversion to 0-5V digital energy_tr Electronic Projects Design/Ideas/Reviews 15 27th May 2008 01:05 PM
Optically isolated analog voltage chip? Fred.Amoson General Electronics Chat 4 11th May 2008 04:41 AM
Minimum analog voltage Shohadawy Micro Controllers 4 4th March 2008 03:02 PM
DC current or voltage regulator, for an analog multimeter steelgod Electronic Projects Design/Ideas/Reviews 4 10th June 2006 09:31 AM
