Take a look at this:
http://www.bandtank.com/~calculusap/notworking.gif the idea is just to continuously flash the light via astable multivibration (555 timer) what it actually does is turn the light on once then turn off then do nothing.... hmmm is the drawing wrong? or did i just do something wrong?
thanks, david |
as far as i know the resistance from +V(pin8) to pin 7 must be greater than 5K. try a greater value for it.
ok now both resistors are 100k
what would cause it to stop after 1 flash??
thanks, david |
The wire coming from pin #7 is wrong - it should connect to 2 resistors instead of one.
I think you have wired 555 in monostable mode or you are missing something. The circuit seems ok except that you have not connected a capacitor of 0.01uF between pin 5 and ground which prevents spurious triggering of 555 due to noise.
"There is no way to peace, peace is the way!" |
hahaha i am retarded. i had R2 connected to 8 instead of 7.
sorry for bothering you with this sillyness kinaljp, maybe i'm just lucky, but i've done several things like this without the cap on pin 5 and i've not seen a problem....
thanks, david |
the cap on pin 5 is for frequency compensation....
use it only on highter frequencies |
In almost all cases you don't need a capacitor there - you can leave it undecoupled. |
yes, i confused it with somehting else
just for feedback: it seems to work with a 1k resistor. duno if its because of the tolerence that it is close enough to 5, or what the deal is. just letting you know.
thanks, david |
well that is what they say in the datasheet......
