Old 23rd May 2009, 02:40 PM   #16
That means you cannot use the supply above as it will be unbalanced.
Use the principle of the following circuit and add another winding to get -5v.
And add another winding for the +5v if you want it to be isolated. Put the windings on an old 10mm antenna rod - 15mmm long.
colin55 is offline
Old 23rd May 2009, 02:56 PM   #17
The schematic attached , is a non isolated and I dont even know calculating turns properly for this topology.
BTW what is meant by "transistor induced shoot through"
PS : I dont have any hard-n fast rules the negative side could be provided more current if that causes an unbalance . Power availablity is a no problem . What I want is isolation . I cannot use a commercial product as I in the next step I will work out for a appropriate certification .
dark is offline
Old 23rd May 2009, 03:17 PM   #18
It's not a matter of "providing" more current, it's a matter of "drawing" more current.
colin55 is offline
Old 24th May 2009, 02:32 AM   #19
Why can't you use a commercial product? Certification is for the entire unit.
straight answer, har har."
Sceadwian is offline
Old 24th May 2009, 07:32 AM   #20
Hi , My client needs ATEX approval and some custom voltages .
Like 5V to 5.25V(200mA) isolation. 3V to 3.3V(250mA) etc . Also the size has to be too small.
dark is offline
Old 24th May 2009, 04:57 PM   #21
Factory made DC - DC isolated converters are fairly cheap and very reliable. Check out any of the big on line electronics supply companies. Digikey, mouser, Allied, and countless more carry about every voltage input and output range you can think of and in power ratings from under a watt to over 100 watts.
All certification requirements are already met too!
"Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
"Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
"Your impossibility may just be my day to day routine." -- tcmtech
tcmtech is offline
Old 25th May 2009, 12:16 AM   #22
Many of the "brick" modules have a terminal that may be used to adjust the output voltage to +/- 10%.
schmitt trigger is offline
Old 29th May 2009, 11:37 PM   #23
And get caught by the authorities for illegally broadcasting a radio signal.
The AM radio antenna will radiate half of the energy as RF.
A better option is to use the ferrite core from an old PC PSU.
if I know the answer.
Hero999 is offline
Old 30th May 2009, 12:47 AM   #24
With all of todays HF transforming frequencies I doubt the FCC is monitoring the 100KHz and below bands with much interest any more.
Technically everything that move electrons and makes an alternating magnetic field is a radio transmitter.
I have a pair of broad band hash transmitters I typically call my 300 amp MIG welder and my 105 amp plasma cutter.
The FCC doest seem to mind my multi KW broad band hash transmissions!
tcmtech is offline
Old 30th May 2009, 02:34 AM   #25
Default where are the inductors?
I don't see any output filter inductors. Also, where's the feedback loop? Do you need regulated outputs? This doesn't appear to be regulated. At the power levels you're dealing with, 1.25W, a push-pull is overkill. A flyback is a good choice if you need isolation. If noise is a problem, then a forward converter is right for the job. The forward requires an inductor for each output.
Claude
Claude Abraham is offline
dcdcpushpull, drawbacks
Ceramic Caps - Drawbacks to Higher Voltage Noggin General Electronics Chat 4 7th December 2008 04:04 PM
